I have a intel core duo 6300 1.86ghz and im looking for the best motherboard for it around 100-200$ ram 8gb 50-100$ graphic card 50-100$ and how much do i need for the powersupply???
Truthfully I would just buy a new cpu, the cost will outway the benefit of even building a pc because the cpu will bottle neck the system so bad, and I am not sure if you can even find a MOBO for that considering it is 8 years old.
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256832
im fine with spending money for a very old cpu, I just wanna make something out of it
I wouldn't suggest buying a new CPU. DDR2 is old, LGA775 is dead. Just buying a 1150 dual core would be a lot faster than that 8 year old core 2 duo with outdated instruction sets.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256856
Not worth it. Go with a G3258
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256864
If you want to buy an old cpu, get a pentium4. It won't fail you. well mine hasn't atleast
He can get a q6600 on amazon for $33, but I still wouldn't suggest it because a $50 1150 cpu single threaded performance has nearly doubled.
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256889
Just get a G3258+Z97 mobo and OC to hell instead of using a C2D.
You can sometimes find a G3258+ Z97 combo for around 100USD.
Just like many users said, get a G3258
CPU Cooler: Silverstone AR03 81.4 CFM Sleeve Bearing CPU Cooler  ($49.99 @ Newegg)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($94.98 @ SuperBiiz)
Memory: Apotop 8GB (2 x 4GB) DDR3-1600 Memory  ($65.70 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.97 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB Video Card  ($329.98 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($69.99 @ Newegg)
Total: $928.58
Generated by PCPartPicker 2014-10-22 21:36 EDT-0400
Edited by mosin40
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256901
Just like many users said, get a G3285
Total: $928.58
You spelled it wrong
https://linustechtips.com/topic/237518-need-help-for-my-build/#findComment-3256959
