Quiet Haswell Build
Solved by The1nf3cted0n3,
Any suggestions? I'm up for anything that looks nice (no noctua) runs quiet and better than the stock cooler (and below $70)
I don't know why but noctua and a sabertooth go so well which each other it is weird but it works look up some builds. I know cooler master makes some downward faces CPU coolers haven't used one of them but I do us a 212 evo
A good gpu cooler would be a direct cu 2 twin frozr whatever his iceq are ones that I reccomend one the AMD side
Get a fractal design define r4 haven't used one but if you work with it (silent components not 30mm annoying fans) is dead silent from what I hear
