I need help choosing a power supply. Id like it to be at the least semi modular and be 80+ efficient. The estimated wattage is 413W. Budget for it is about $70 USD, anything less is great. Thanks for any suggestions :)
Build: http://pcpartpicker.com/p/Qxr8xr
Runescape player  II  Civ 6 and LoL noob  II
https://linustechtips.com/topic/237004-need-help/
Keep in mind that PcPartPicker gives a very rough estimate.  For that kind of a build definitely get 600+ watts
Corsair CX600M
Use this one if that is all the money you can spend toward a PSU
If you can save another $20 I would highly highly recommend going with the Cooler Master VSM (650)
https://linustechtips.com/topic/237004-need-help/#findComment-3249788
Since you have a budget for $70, get the seasonic ssr-550rm. It's an 80+ Gold rated unit & costs $80.
If you want something cheaper, the CX-500 is okay.
Personally, I won't skimp on the PSU.
Edit: Since you're getting a non-K cpu, the H80i is overkill. Get the hyper 212 Evo.
https://linustechtips.com/topic/237004-need-help/#findComment-3257543
Corsair CX600M
Since you have a budget for $70, get the seasonic ssr-550rm. It's an 80+ Gold rated unit & costs $80. If you want something cheaper, the CX-500 is okay. Personally, I won't skimp on the PSU. Edit: Since you're getting a non-K cpu, the H80i is overkill. Get the hyper 212 Evo.
A cx500m wouldn't be skimping much on the psu. The system would pull ~350w at load.
The aftermarket cooler is a waste of money considering it's not really quieter than the stock cooler and that the cpu is n't unlocked for oc'ing.
https://linustechtips.com/topic/237004-need-help/#findComment-3266311
