So I finally attempted again to get a high/stable overclock on my cpu again. After a lot of playing, the highest stable overclock i could get was 4.6ghz @ 1.27v with temps avg. at around 66-68c... this seems rather low for me... and no matter what i give her (volts, multiplier) I cant get any higher... any suggestions?
Asus Sabertooth Z77, 3570K, H100i in push pull, 16g of Mushkin 2133 ram running at 1866
https://linustechtips.com/topic/23684-3570k-overclocking-wall/
It looks you've hit an OC wall on your CPU.
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300118
4.6Ghz is pretty good, I think I'd just leave it like that
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300163
Yea, a 1.2Ghz increase should give a little performance kick lol
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300401
Some really good info in this Asus OC 4th Gen OC Guide, give it a read through and see if you cant squeeze a little bit more out.
P.S it's a 3MB PDF
Main Rig: i5 760 @ 4.0GHZ Asus p7p55d-e, 8GB Corsair Vengance @ 1600 Mhz. Samsung BX2231 X 3 (5760x1080)
                EVGA GTX 680 Superclocked +150/+500, 128GB Crucial M4, 1TB WD Black
                Xonar DX, AudioEngine A2, Astro Mixamp, AudioTechnica ath-m50 & ath-ad700
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300469
I have one more suggestion for you if you have 4 dimms of ram installed, remove 2 and give that a try just for OC sake, and the other thing you might try is put memory to CAS 9 and speed at 1600, that is the last thing, and just keep in mind that as Linus already said, about 50% of the chips made go to 4.5/6 ghz, 25% 4.7 ghz and that percentage keeps decreasing the higher you go...
System
CPU: i7 4770kMotherboard: Asus Maximus VI HeroRAM: HyperX KHX318C9SRK4/32 - 32GB DDR3-1866 CL9 / GPU: Gainward Geforce GTX 670 Phantom Case: Cooler Master HAF XBStorage: 1 TB WD BluePSU: Cooler Master V-650sDisplay(s): Dell U2312HM, LG194WT, LG E1941
Cooling: Noctua NH-D15Keyboard: Logitech G710+Mouse: Logitech G502 Proteus SpectrumSound: Focusrite 2i4 - USB DAC / OS: Windows 7 (still holding on XD)
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300517
Just take what you got out of it and get the least voltage you can out of it. That is unless you have the money to keep trying to risk death upon your CPU. :P
CPU: FX 8350 @ 4.5ghz w/ Corsair H80  RAM: Kingston HyperX Predator 8GB(2x4GB) 2400MHz CL11 HDD: Kingston HyperX 3k 120gb SSD(Boot drive) Seagate 7200rpm 1TB HDD(Storage) Motherboard: Gigabyte 990FXA-Ud3
PSU: Corsair AX860i GPU: 7950 3gb Case: Rosewill RSV L4000
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300584
What a coincidence, I was just messing around with my clocks on my 3570k.
I typically undervolt to 1.08 and run at an even 4GHz, but I wanted to see how far I could push it within reason.
I got mine on a silverstone HE01 with the fans all still set to quiet mode to 4.4GHz at 1.22V with the hottest core hitting 78 degrees under OCCT Linpack.
I'm pretty happy with that.
Next step is to make an eco mode that runs undervolted at stock clocks, see how cool and quiet this sucker can get.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-300693
My chip had the exact same problem. No matter what settings I changed or increase in voltage, I could not do higher than a 46 multi. Worked out in the long run though because my cooling would not be able to keep up with any more volts. With 4.6ghz and 1.33 volts I was right at the borderline. As long it does not thermal throttle during stability testing I am happy though. 24/7 and in games my temps never go above 70 C.
CPU-[i5 3570k-4.6ghz at 1.33v]  GPU-[4gb Zotac GTX 680 1126 core 6800 mem]   MOBO-[Gigabyte Z77 UD4H]   PSU-[Corsair TX 650]   RAM-[2x8gb DDR3 1333 GSkill Ripjaws X]   Case-[Corsair 550D (2xNoctua NF-F12, 1xNoctua NF-A14 intake, 1xNoctua NF-A14 exhaust)]   CPU Cooler-[Noctua NH D14]   Boot Drive-[Crucial m4 256GB SSD]   Game Drive-[500GB Western Digital Caviar Black]   Storage Drive-[2.5" 500GB Western Digital Scorpio Black]   Sound Card-[Asus Xonar DG]   Optical Drive-[Lite-On IHAS-124]  Monitor-[Dell U2312HM] Keyboard-[CM Storm Quickfire Rapid-Brown Switches] Mouse-[Logitech G400] Speakers-[Klipsch Promedia 2.1 THX]
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-301175
Well you could clock it unsynced. Run Intel burn test on your stable overclock and then look at realtemp. Usually one or two cores will get quite a bit hotter than the others. Set those cores' multipliers to 45-46 then go for 47-48 on the low temp ones.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/23684-3570k-overclocking-wall/#findComment-302455
