I know I should've googled this and trust me, I did and that's the reason why I am asking this to you guys.
Apparently, something doesn't really add up when it comes to the actual dimensions of the Gigabyte GTX 970 G1 Gaming. (This one).
The site said it's 12. something inches, while Newegg and some other sites said it's 15.9 inches! Now this becomes a problem since I have this for a case:
Bitfenix Comrade Window White
I measured the Comrade and it will fit if the card is indeed 12. something inches long.
This is where I need your help guys, will it actually fit? I was hoping that there are guys here who are either better at googling or actually owns both the case and the card (or either will do) and can tell me that it actually fits without dismantling the built-in drive cages(I really wish these can be detached).
Apologies if this is a dumb question but I don't know, I'm just really confused right now.
Thanks in advance for all the inputs! :D
P.S. In the sad and unfortunate case that it does not fit, what other cases can I consider that is at least close to the compact-ness of the Comrade, color white, and has a window (I'm a show-off, sue me)? Thanks again! :D
Intel i5 4460 || Deepcool Gammaxx S40 || Gigabyte H97 Gaming 3 || Corsair Vengeance 2x4gb DDR3 1600 CL9 || Gigabyte GTX 970 G1 Gaming || WD Caviar Blue 1TB || Asus 24x DVDRW OEM || Bitfenix Comrade Window White || Asus VX239h || Razer Blackwidow 2013 || Razer Deathadder Chroma || Windows 8.1 x64 SL || Crucial M550 256gb || Deepcool RGB Led Controller
https://linustechtips.com/topic/236573-will-it-fit/
I have no idea why pc part picker says max card length is only up to 11.81" which if you take a look at it, it's an 18.5" deep. The mid drive cage is for 2.5" drives, so say 3.5 inches wide. Where are the other roughly 3.2" going? I think there is more room than that. maybe another inch for the front panel? So im thinking at the very least it can fit a 14" card.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/236573-will-it-fit/#findComment-3242648
Thanks for the input guys, now I just need someone here who actually owns the graphics card and give me what is the actual measurements. I have trust issues with google now, sorry guys if I had to lash it out here :(
https://linustechtips.com/topic/236573-will-it-fit/#findComment-3243377
