Looking to put together an HTPC. Here's what I've narrowed down so far:
http://pcpartpicker.com/user/Method320/saved/xcwmP6
Is the G3258 good enough for an htpc? Won't be doing any gaming, just movies/tv shows. What should I put in for a video card? I have a spare 460 laying around.
CPU: Ryzen 5800X | GPU: RTX 3080 FE | Board: x570 Aorus Master | RAM: 32GB GSkill TridentZ | Case: Phanteks 719
https://linustechtips.com/topic/236507-mini-itx-htpc-build/
You can get away with a much lower end chip, with a built in GPU so you don't need a video card.
Unless the G3258 has an integrated GPU?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241575
According to ARK it does: http://ark.intel.com/products/82723/Intel-Pentium-Processor-G3258-3M-Cache-3_20-GHz
I just want to make sure it can drive super high quality 1080p movies.
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241580
I'm pretty sure 1080p is 1080p...that's the quality.
It'll be more than capable I'm sure. Especially if you're comparing it to your ancient G Force card. My integrated HD4000 graphics do just fine for me.
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241592
For media streaming you could even get a baytrail-D mobo with a J1900. they are ultra low power and fast enough. Also consider not getting a ssd as you probally won't notice it as all you would do is stream videos. also if you go for the Pentium get a cheap mobo you don't need z97.
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241596
Eh, thats not really how that works lol. 1080p is only the resolution. Then you're talking about bitrate, codec, etc
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241603
True, I suppose I dont need z97. Good call. Ssd was thrown in because I have one lying around. This will likely get paired together with a 4tb raid 1 setup across 2 drives or something.
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241606
And at the end of the day, it's video. Not an issue for the integrated graphics.
https://linustechtips.com/topic/236507-mini-itx-htpc-build/#findComment-3241615
