format drive and reinstall windows?
yes
A simple reinstall wont rid the drive of your files. If somebody really wanted to they could still recover data (not that I suspect they would) But if you want to be really secure run a bootable disk image of DBAN and input "autonuke" when it ask for a command... it may take a few hours but it will get rid of all your data. After its done you are free to reinstall windows for the next person.
http://www.dban.org/
Quack 🦆
https://linustechtips.com/topic/235897-hard-drive-cleanup/#findComment-3232751
Burn/destroy the HDD, have them thier own. Only Secure method.
This guy speaks the truth.
Just to let you know most places (ebay included) tells you in their ToS your not allowed to sell used machines with HDD included.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/235897-hard-drive-cleanup/#findComment-3236775
Peel the sticker off, to locate a hidden screw.
Remove that screw.
Drill hole through screw hole all the way through HDD.
Fill hole with water and baking soda.
Remove water mixture.
Replace screw.
Burn.
Dig hole.
Place in hole.
Cover hole.
Build house over hole.
317 is watching. 317 is everywhere. 317 is life.
https://linustechtips.com/topic/235897-hard-drive-cleanup/#findComment-3237545
