hello. im just wondering if this motherboard will work with my build. i bought the wrong motherboard and dont want to screw up again. will this motherboard suit all the purposes of my build
my graphics card http://www.ebay.com.au/itm/GIGABYTE-GT630-2GB-Gaming-Video-Card-nVIDIA-GeForce-Graphic-2048MB-HDMI-DVI-VGA-/230834429032?pt=AU_Components&hash=item35becddc68
my build. with discontinued motherboard http://au.pcpartpicker.com/p/HCWjvK
the  motherboard im thinking of getting http://www.asus.com/Motherboards/A88XMA/specifications/
https://linustechtips.com/topic/235380-pc-build-motherboard/
The motherboard will work fine, but I implore you to not purchase that video card. Save up a little bit more and get something that is actually worth the money, like a GTX 750/R7 250X at the minimum.
https://linustechtips.com/topic/235380-pc-build-motherboard/#findComment-3225057
ive already got it. and im not a real graphics guy. i used to play on a laptop at lowest settings. its fine. i just wanted to know for the motherboard
https://linustechtips.com/topic/235380-pc-build-motherboard/#findComment-3225072
In that case, alright. The motherboard is fine.
https://linustechtips.com/topic/235380-pc-build-motherboard/#findComment-3225079
youd  be better off getting a pentium G3258, overclocking it, and pairing it with a GTX 750Ti. That'll give you MUCH higher perf for the same price as you/re looking at paying now. APUs are a fool's purchase IMO.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/235380-pc-build-motherboard/#findComment-3225221
