I just bought a new case, an i5-4590, and a new motherboard, z97X-SLI. I bought them together on newegg, and after assembling, idle temperatures are 60-70 C and when ever I start any basic game, minecraft to tf2, nothing too demanding, it easily reaches 100 C. I have no clue what's going to but to say the least I'm scared. I have the stock fan on, but i've never heard of someone getting this high temp with the stock cooler. Should I get a new cooler or is it an issue with my case? The case I just bought is the NZXT S340.
https://linustechtips.com/topic/234838-massive-overheating-i5-4590/
I would make sure that you installed the cooler correctly and tightly. If it is then I would try re-applying thermal paste.
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
I'm using the stock cooler that came with the I5, Where do i buy thermal paste?
You can get it at various online places and PC parts shop, probably where you bought your PC parts also carriers some :)
You can buy it anywhere that sells Pc parts pretty much
What they said as well
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
Re-install the cooler apply new thermal paste
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
If you're on a budget, get a CoolerMaster Hyper 212.
Fits in your case and is a great budget cooler.
Please be sure to use iso-propyl alcohol or Methylated spirits to clean the existing paste off your CPU.
CPU i5 6600K | Mobo Gigabyte Z170X Gaming 7 | Cooling H80i | MSI GTX970 Gaming 4GB in SLi | Geil Super Luce 16GB 3000MHz DDR4 | Intel 330 120GB | 2 x 1TB WD Black | Corsair Air 540 | XFX ProSeries 1250W. | Corsair K70 Anodised Black Cherry Reds | Logitech G502 | Dell U2713HM | Red LED Lighting.
Portable Gamer - Metabox Alpha W370SS - CPU i7 4710MQ | RAM 8GB 1600MHz | Nvidia GTX 860M 2GB GDDR5 | Samsung 840 EVO 250GB SSD | 17.3" Matte Display 72% Gamut
Back-up - HP Pavilion dv6 - Ancient Stuff - P7550 @ 2.26gHz  | DDR2 4GB | Kingston HyperX 120Gb SSD | ATi 4550m (fried)
^This.
If you wish to remove and reinstall the stock cooler, you will need to apply fresh thermal paste, as thermal paste/pads are not reusable.
First, wet a lens cleaning cloth or another similar lint free soft cloth with 99% isopropyl alcohol (don't soak it) and rub the old thermal paste off the heatsink and CPU. Keep rubbing with fresh alcohol until the cloth comes away completely clean. Next, take your thermal paste and apply a dot the size of about 1/3 to 1/2 of a green pea of thermal paste right in the center of the CPU. Then lower the heat sink onto it.
What has likely happened is that you have not properly pushed all 4 pushpins of the stock cooler down into the motherboard.
Still, Hyper 212 is way better, runs way cooler, and has a way better more secure mounting system that actually screws down. If you have $30, buy one.
I suggest MX2, MX4, or NTH1 thermal compound. Avoid Arctic Silver as it performs poorly, takes 200 hours to break in, and is capacitive, meaning if you get any where it doesn't belong it'll cook your mobo.
Intel Inside. Overweight guy in his 30's outside.
