IS your OS 32 bit or 64 bit? 32 bit uses only up to 4 gb.
https://linustechtips.com/topic/234749-ram-help/#findComment-3215077
so i just put together a gaming rig and everything seems to be fine except the ram, It says8 gigs are installed ehich it is, but only 3.97 is usable. PLEASE HELP
Did you install a 32bit OS? If you want to be able to use all 8GB you have to patch the windows kernel or install x64.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/234749-ram-help/#findComment-3215104
