Best UK modding supplier
Go to solution Solved by jd2195,
http://www.e22.biz/ sells Lutro0 customs sleeving and all of the tools required if you want to sleeve the cables yourself
http://www.specialtech.co.uk/spshop/home.php sells all sorts of modding equipment such as lighting
http://www.overclockers.co.uk/index.php sells pre-made braided cables and also sells lighting
Mod it in what way
https://linustechtips.com/topic/234372-best-uk-modding-supplier/#findComment-3203225
just the easy stuff cable sleeves lighting....
You can buy sleeved cables and led lighting from tons of stores like overclockers etc
http://www.kustompcs.co.uk/acatalog/Braiding.html -  these guys do custom sleeving
https://linustechtips.com/topic/234372-best-uk-modding-supplier/#findComment-3203267
My rig: i5 2500k, MSI Z77A G45, Gainward GTX 980 Phantom, 8GB Corsair Vengeance, OCZ ZT series 750W PSU, 1TB HDD, 800D, fully water cooled. I am currently working on modding my HAF 912+ to fit a custom loop, here is the build log: http://linustechtips.com/main/topic/165963-project-viridis-water-cooled-haf-912/
https://linustechtips.com/topic/234372-best-uk-modding-supplier/#findComment-3209129
