All right so i have a z77a-g45 from msi and i also have a i3-3220 along with it, i was thinking of getting a i7-4790k but i dont know with which platform to get it with (z97 or z87 ) i know that z97 mobos are new and all but that would require more money, you can use 4790k with z87 mobos right?
https://linustechtips.com/topic/233935-confusedneed-help/
you can but you will need to update your BIOS first (which requires compatible cpu)
https://linustechtips.com/topic/233935-confusedneed-help/#findComment-3196848
Yes, you may have to do a bios update upon installation, but yeah. It'l work just fine.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/233935-confusedneed-help/#findComment-3196852
Z87 is technically compatible and its fine if you're actually getting a better deal that way. But if you go that route I would recommend double-checking the manufacturer's product page for the board you're looking at to make sure it actually got the BIOS update for -4790K compatibility. I think most did, but I wouldn't be certain enough to bet money on it.
https://linustechtips.com/topic/233935-confusedneed-help/#findComment-3196879
