Help with my build
Go to solution Solved by WolfDeville,
skip the keyboard for now, just get a cheap membrane one for $10 and get this http://www.gumtree.com.au/s-ad/sydney-city/software/windows-8-1-professional-for-1pc/1059274614 then you will have an extra $235 for a better graphics card.
Edit: oh and get a WD Black or Blue, not Green.
Edit again: If you get a cheaper case you could probably add in an SSD, which would be really worth it.
Hi my name is Jayden, I'm 15 from Australia and I am wanting to make my first build. I would rather keep the cost of the pc as low as possible, but I would also want to play the latest games with ease at high graphics. A couple of my mates helped me out a little bit. I am basing my build at PC Case Gear.
I've updated my cart down below. I want to keep it under $2000. I changed the motherboard and the HDD, I want to keep the power supply as it is. I also don't want an SSD for now. I like this water cooling system as it will look amazing when it is done. Please tell me you thoughts on this build
My cart:http://www.pccasegear.com/sc/jne
Check it out and please help meeee :)
Edited by Jayden.Viv
https://linustechtips.com/topic/233932-help-with-my-build/
Never get WD Green HDD, get Seagate SSHD instead.
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3196847
Get 1866mhz ram version, get the maximus VII Hero, get EVGA FTW version of GTX 750 Ti 2 GB,
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3196861
Your color scheme is really nice tho
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3196867
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3196868
He says he want to get the cost as low as possible, since he's building this rig for gaming, I don't see him spending that much on storage.
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3196873
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3197061
thanks guys for you input, my budget is under $2000 and I will change the hard drive to black. I don't want an SSD for now, although it will be on my mind in the future.
I've never mucked around with an SSD before and if I don't I'll never know what i'm missing out on, therefore i'll never regret not buying one.
I just added my new update in the first post :)
https://linustechtips.com/topic/233932-help-with-my-build/#findComment-3219600
