CPU heat concerns
Go to solution Solved by Clyne,
I'm running the stock cooler on my 8320 with two fans intaking air into the case, temps will be fine.
@i_build_nanosuits had a 8350 with 2 fans as one intake and one outtake and it works fine for him but he sold that cpu for a i7.
I'm going to be upgrading my CPU from an AMD FX-6300 to an AMD FX-8350. Currently, my 6300 runs fine with the stock fan, and my machine currently has two fans (one pulling air in and the other pushing air out) and if I absolutely have to I may be able to add a third fan on the top of my case. Before I purchase the 8350, I want to be sure that it won't get dangerously hot as AMD CPUs seem to have that reputation. Will it come with a competent fan or will I have to buy a new one? Like I said, the 6300 runs completely fine so if the heat output is similar I shouldn't need to worry about it much.
Thanks so much for the support in advance. I'm relatively new to this stuff and I want to be sure I'm making good upgrade choices.
EDIT: I'm completely new to this forum so wether this belonged in this board or the Air Cooling board was beyond me.
https://linustechtips.com/topic/233799-cpu-heat-concerns/
it should be fine... it may just depend on your room temperature and if you have a cooler on or not. and season probably because in australia is 30 degrees celsius in summer and near 0 degrees celsius in winter so that will have impact as well.
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/233799-cpu-heat-concerns/#findComment-3194901
As long as you're not overclocking you don't NEED an aftermarket cooler. That being said, it's better overall if you had something cheap like a Hyper 212+. You should be fine though if you're not rendering videos 24/7 or pushing it to 100% usage all the time.
RIP in pepperonis m8s
https://linustechtips.com/topic/233799-cpu-heat-concerns/#findComment-3194902
