Building a pc for first time and have some questions
Jeiik
So I’m Building a pc for first time and I need some help about the components, I work with 3D software like 3d max, maxwell, vray and edit video too, but no to a pro level, I just finish uni and I’m starting in business so about getting quadro’s and that I’ll come in a few years . Also like to play games I’m at League atm, but I never had a chance to play those games with fancy graphics so here is my chance to do it :D,  basically I want that you tell me if I can replace something with another thing cheaper o better according to my needs so I can save money because I’ll spend a lot with shipping because I’m on México(still cheaper that those excessive expensive 500/700 usd gtx 970 in here)  hope in the future I can add more RAM and another video card so my first question is:
 Should I get a full tower or a mid-one if I plan to SLI 2 cards?
$119.99 - Nzxt Technologies Phantom with Green Trim (Green LED) Enthusiast Full Tower Case - Phan-002Gr (Black) - http://www.amazon.com/NZXT-PHANTOM-Tower-White-PHAN-001WT/dp/B003WE9WQO/ref=sr_1_14?ie=UTF8&qid=1413321453&sr=8-14&keywords=nzxt
$329.99 - EVGA EVGA GTX 970 4GB GDDR5 256bit - http://www.amazon.com/EVGA-Superclocked-256bit-Graphics-04G-P4-1972-KR/dp/B00NI45AUU/ref=sr_1_4?ie=UTF8&qid=1413323377&sr=8-4&keywords=gtx+970
$329.99 -  Intel Core i7-4790K Processor - http://www.amazon.com/Intel-i7-4790K-Processor-Cache-BX80646I74790K/dp/B00KPRWAX8/ref=sr_1_1?ie=UTF8&qid=1413323513&sr=8-1&keywords=intel+i7
$132.99 Gigabyte GA-Z97X-GAMING 3 LGA 1150 Z97 Gaming Audio and Networking ATX Motherboard - http://www.amazon.com/Gigabyte-GA-Z97X-GAMING-Gaming-Networking-Motherboard/dp/B00K2RQDXY/ref=sr_1_2?s=electronics&ie=UTF8&qid=1413323833&sr=1-2&keywords=lga+1150+sli
$182.99 - Corsair Vengeance Pro 16GB 2x8GB DDR3 2400MHz PC3 19200 Desktop, Red CMY16GX3M2A2400C11R - http://www.amazon.com/Corsair-Vengeance-2400MHz-Desktop-CMY16GX3M2A2400C11R/dp/B00EUPV2RQ/ref=psdc8_t1_B006EWUO22_B00EUPV2RQ
Ok, about power supply I know nothing
should I buy extra fans?
Extra pieces I don’t know?( cooler, thermal, cables or those things come to my mind)
Well thanks for the time and sorry for my bad english :D
The phantom should be all right
With a SLI you can have a mid or full tower.
If you live in mexico buy MX-4 Thermal paste and you can add one or two fan
A mid tower should be fine.
How much is your budget, try to use PCPartPicker
Edit: Welcome to the Forums  :lol:  :D
Edited by mosin40
What do you think about this:
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($74.99 @ NCIX US)
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard  ($238.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card (2-Way SLI)  ($329.98 @ NCIX US)
Case: Thermaltake Core V51 ATX Mid Tower Case  ($109.99 @ Amazon)
Total: $1747.87
Generated by PCPartPicker 2014-10-14 18:20 EDT-0400
Total: $1747.87
remplace the adata sp600 by a Corsair MX100 256gb
So i like this build, ill add the corsair like warplan said and i think im going with the Nzxt case and maybe buy 2x8 rams because i wanna reach 32 one day, thx a lot for your help :D
did you mean crucial mx100 warplane?? that's what i found not corsair ones, and  about te mobo  specs says that "DDR3-1333 / 1600 / 1866" so it is pointless to get higger rams like thoses ddr3-2133? and other thing should i wait to black friday to buy the parts online? well thx a lot for your help guys :D
Total: $1904.21
Total: $1904.21
Can you do the Mail in rebate from Mexico ? If so then go for the EVGA Supernova G2 rather than the NEX.
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
Still don't know how rebate works, ill send everything to the house of a friend on texas then ahother friend will go to usa and pick up the parts, if rebate involves a lot of work it will be not posible to me bacause i dont wanna bother my friend on usa T.T, thx for your suggestion :D
