need help upgrading?
Go to solution Solved by givingtnt,
Sory but that link is not working.. only gives me the website with no parts selected
lol oups xDhttp://ca.pcpartpicker.com/p/qWnNBm
Hi.
Current setup:
PSU: Seasonic M12ii-520 Bronze (520watt)
MB: MSI H61M-P20 G3
CPU: Intel core I3 3220 3.3ghz dual core
CPU is liquid cooled:
Thermaltake Water3.0 Pro (push+pull)
GPU: EVGA gtx 650ti 1gig 128bit
RAM: 8gb 1333mhz
If I upgrade to core I5 and MSI gtx 760 twinfrozr, wil I be able to play for eg. Battlefield 4 with 70+ fps? At least setting on medium or higher.
And if not, maybe you could recomend something else?
Thanks in advance
https://linustechtips.com/topic/233114-need-help-upgrading/
ok so thats about 540$ US
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185647
how about an i5 4690k with a z97motherboard and a gtx 760 or r9 285x ?  just have to find palaces to buy them
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185658
wait thats an mITX board O.o
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185673
I can buy the 4690k and the 760. But wont be able to afford the z97 also
how about a 4690 and h97 mobo. that would work
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185679
https://ca.pcpartpicker.com/parts/partlist/
here. this is a tiny bit over budget but well worth it
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185693
around  6,444.02 rand
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185703
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185752
Yip it works now thanks* Can I just ask why I need the new mobo? Mine isnt that bad is it?
Because it's a different socket...
Also, can you give us a link to a site from the shop you're buying from, since i guess prices are quite different O.o
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185827
thats because the cpu is an 1150 socket. yours is an older 1155 socket. also the motherboard's chipset won't work with haswell cpu's :)
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185836
Oh i didnt even think of that. Sory. But here is the site i would like buying fro as I trust them and bougt my previous build from them. www.evetech.co.za
This is quite a... bad site...Can't even find CPU category...
This is what i've got, and you can even lower it by using 760 :D
http://prntscr.com/4w8ev5
https://linustechtips.com/topic/233114-need-help-upgrading/#findComment-3185909
