My computer has a problem. I have to shake my tubing/knock on my waterblock before my computer boots. Also my computer shuts down when the CPU gets near 50 degrees. I use watercooling.
How to fix this?
CPU: AMD FX-8350 (No overclock)
MB: ASUS CROSSHAIR V FORMULA-Z
GPU: GTX 780 GIGABYTE
MEM: 16GB 2400MHZ HYPERX BEAST
PSU: 700 WATTS
CPU COOLER: CORSAIR H110
Thug life.
https://linustechtips.com/topic/232976-how-to-fix-motherboardcpu-problem/
Do you have the latest drivers? (BTW dat name doe)
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
i'm not very experienced with water cooling but sounds like you got junk in your loop, also it sounds like you may have an issue with your PSU, considering the 8350 throttles at 60, can you give me a model number and when you purchased it?
Build: Sister's new build |CPU i5 2500k|MOBO MSI h61m-p23 b3|PSU Rosewill 850w  |RAM 4GB 1333|GPU Radeon HD 6950 2GB OCedition|HDD 500GB 7200|HDD 500GB 7200|CASE Rosewill R5|Status online
Build: Digital Vengeance|CPU i7 4790k 4.8GHz 1.33V|MOBO MSI z97-Gaming 7|PSU Seasonic Xseries 850w|RAM 16GB G.skill sniper 2133|GPU Dual R9 290s|SSD 256GB Neutron|SSD 240GB|HDD 2TB 7200|CASE Fractal Design Define R5|Status online
  • 7 months later...
Also, the not powering up thing is like this: The motherboard shows FF on the little display and the case button lights don't turn on. If i move/kick the pc, the numbers start going, the fans crank up, the leds start blinking and it boots.
Thug life.
"The Magic Kick", eh?
I reccomend that you read through this. (Litterally the first thing that came up when searching your mobo name and error code, seems to be a solution to your problem)
https://rog.asus.com/forum/showthread.php?52494-Asus-Crosshair-V-Formula-Z-FF-error-DRAM-light
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
