Hello guys and girls,
Since the new Nvidia driver (320,xx) came out a couple days ago (the one which including geforce experience) i got some huge
graphical artifacts and polygons especially in Battlefield 3. Found a Video on Youtube which show exactly how it starts to look on my screen after about 10 minutes of gameplay:
My Temps don´t go beyond 70°c and i got about 920mb/1gb memory usage according to MSI afterburner.
Got a Gigabyte GTX 560 Ti OC. Already clocked it down to 822mhz and got the memory clock on 1900mhz.
Does anyone know what to do to get rid of this ?
Thanks for your responses!
greetz Mexxim
My System: AsRock Z77 Extreme4-m, Intel Core i5 2500K @4 Ghz, 8 GB of RAM, ASUS GTX 970(4GB)
1 TB of SSD Storage, BeQuiet Pure Power 730W PSU - All stuffed in a Corsair Obsidian 350D
https://linustechtips.com/topic/23244-graphic-problems-with-560-ti/
I heard a rumour that Nvidia had released another driver that kills cards.
I heard this as well. Have you updated your Drivers lately?
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
I updated to the latest driver after there was a notification on the taskbar telling me there was a new one. And then the trouble started.
But i already deleted that one and got version 314.22 back on. Still same problem ..
whoa, if this rumor was true..big lawsuit.
I have never seen anything like this happen to AMD
Main Rig:
I7 3820 @ 4.3GHZ---Corsair H100i---EVGA X79 FTW---DDR3 2133 16GB--- Asus GTX 780 DCII--CM Storm Trooper---corsair AX860---OCZ vertex 4 256GB--WD BE 1TB
Turning off MSAA fixed this for my 550's in SLI, if it's any help.
"Don't make a girl a promise, if you know you can't keep it" | "Didn't you hear? Spartans never die."
-Gaming- FX 8150 @ 4.2GHz, HD 7870 Tahiti LE 2GB @ 1.1GHz, ASRock 990FX Extreme3, 8GB DDR3 1333 MHz, WIndows 10, Custom Watercooled, NZXT Switch 810
-Audio Editing/Mixing- Mac Mini Late 2014, Core i7 3.5Ghz, 8GB RAM, 2TB Fusion Drive, OSX 10.12 El Captain -Phone- HTC One M7 32GB
This artifact-trouble with nvidia-cards and the Battlefield-series happened before. What they did was making sure that the core and memory clock speeds of the card remained stable when they played Battlefield, maybe that could help you.
So you rolled back your drivers. Do you know if the installation of the newest drivers changed any game-settings? If that is the case and the roll-back did not change them back to how they where, it is probably a settings issue. You could try to use another type of AA or disable/enable some texture- or filtersettings in the nvidia-control panel.
Wi RoZ
I let GeForce experience "optimize" battlefield 3 once. It turned everything on ultra except textures on low. and than i got about 20 fps so this didn´t work. but now set my settings from before in the Nvidia control panel including turning off AA and AF completely. I will try some gaming now and hopefully it will work fine again... I will post whatever happens afterwards.
*EDIT* it doesn´t work. especially on ziba tower everytime a new round starts it looks like that. In my opinion it gets worse too -.-
I have the exact same problem with my 560ti but also on videos of any kind, Youtube or just playing a video in a player it begins to stutter and slow down just like you would see on a game when your fps is something like 15fps after some time of idle (not moving the mouse or interacting with the computer) then as soon as I move the mouse it's back to normal. :/
  • 2 weeks later...
Please check your voltage, that driver is known to kill fermi cards, by putting loads of voltage through it, if that's the case, your card is almost dead, try a RMA.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
