Alright, so I own a Logitech G430 headset. It comes with a USB soundcard that allows (somewhat decent) 7.1 surround, or normal 2 plug jacks. Now my problem is that every time I start the computer, I can hear everything from the mic in my headset. I disabled every "listen to device", and have no clue what to do. I can temperarally fix it by changing the advanced format to something different (High quality CD to DVD or something) and it fixes the problem. This makes me think another program is using the mic, but what could cause that?
Thanks.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/232199-i-need-mic-help/
Do you have it plugged in via usb or the headphone and microphone jacks? if using the two jacks, are you plugging them into the front or back ports?
https://linustechtips.com/topic/232199-i-need-mic-help/#findComment-3174174
I use the USB adapter for the 7.1 surround sound.
The Grey Squirrel
https://linustechtips.com/topic/232199-i-need-mic-help/#findComment-3176109
Try using it without the usb adapter.
https://linustechtips.com/topic/232199-i-need-mic-help/#findComment-3176144
Then I won't be able to use the surround sound feature...
The Grey Squirrel
https://linustechtips.com/topic/232199-i-need-mic-help/#findComment-3176483
