NZXT H440 Fans Problem
Luchosott
Hi people, I recently bought some NZXT 120mm v2 fans to add to my H440, I put them and I did all the cable management again to let that side panel close perfectly, but now I have a problem, all the fans connected to the H440 fan controller don't work, the only fans that work are the cpu, gpu and psu, something stange is that the back led does not work too.. Any recomendation?? I don't know what to do..
You need to plug molex power into the fan/led controller.
well...What it sounds like is the power to the fan hub is disconnected. The back led's are connected to the same fan hub, check and re-check the wiring to the fan hub and see if it fixes it
Home is where the heart my desktop is.
The molex that comes from the case it's connected to a psu molex, so idk what's the problem :S
try a different molex connector
