Currently diagnosing a newly built system - no OS installed yet. When powered on, the fans spin up, but keyboards are not detected (no num lock light) and there is no motherboard splash screen on the monitor. I've tried running the system without a GPU installed, with different RAM configurations and checking everything is plugged in correctly to no avail. Any advice?
Motherboard: MSI A88XM-E45
CPU: AMD Athlon X4 860k
GPU: Asus GTX 760 DCUII
PSU: Corsair CX 500M
HDD: Seagate 1TB SSHD
RAM: 8GB Kingston HyperX Fury 1866MHz
Case: Fractal Core 1300
Check out my video work at youtube.com/SuperUserTech
Acer Aspire 5750G - i5-2410m | 8GB 1333Mhz RAM | 500GB 5400RPM HDD | Nvidia GT540m
2xBenQ EW2440L | Sennheiser HD600 | Corsair Vengeance K65 | Corsair Vengeance M65 | Panasonic Lumix G7 | Panasonic 20mm F1.7
https://linustechtips.com/topic/231230-system-not-posting/
Well you will need the GPU installed since that CPU doesn't have integrated graphics, Try clearing the CMOS, boot with only one ram stick installed and reseat the CPU.
https://linustechtips.com/topic/231230-system-not-posting/#findComment-3162131
Try clearing the CMOS. Sometime that is all that is needed.
To do this, you just unplug the PC from the wall, and remove the motherboard battery. Then press the power button for a couple of seconds.
Remember to reinsert the battery when you are done.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/231230-system-not-posting/#findComment-3162139
I have tried all, to no avail. Any other advice? My main suspicion is that the motherboard is running an older BIOS version that is incompatible with this CPU.
https://linustechtips.com/topic/231230-system-not-posting/#findComment-3162155
It is possible.
Is there any way you know of of checking? If so, is there any way to flash the latest BIOS while the system is unable to POST?
https://linustechtips.com/topic/231230-system-not-posting/#findComment-3162232
I don't know if you can flash the bios without being able to post. I know Asus boards you can flash the bios without a CPU or Memory installed. You might have to go to a shop and ask them to install a CPU and flash it. I will do some googling and see what I can find.
https://linustechtips.com/topic/231230-system-not-posting/#findComment-3162270
