Help choosing a CPU!
Go to solution Solved by lukasaerik,
Get the i7 4790K, it is undoubtedly better than the similar priced AMD options.
I'm building my first PC soon for gaming/ video editing/ 3D animation and i'm a little bit stuck on the CPU. I've chosen the intel i7 4790k 4GHz Quad Core. BUT i've noticed for around the same price i can get an AMD CPU with more cores and just under the same GHz. Any help?
https://linustechtips.com/topic/231192-help-choosing-a-cpu/
AMD CPUs are old and much less "powerful" (due to it being of very old architecture (2012)). If you want a cheaper CPU get the intel xeon 1231 v3, basically a i7 4790k which you can't overclock (not important anyway).
Samung Tab S 8.4
https://linustechtips.com/topic/231192-help-choosing-a-cpu/#findComment-3161656
i7-4790k is similar/better than any AMD CPU for  gaming/ video editing/ 3D animation !
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/231192-help-choosing-a-cpu/#findComment-3161671
