hi guys. i already did my first post. its really good 2 be here. please help me cuz in a few months ill start buying the parts needed for my futureproof rig. i wanna be able to play all the latest games on (as much as possible) max settings, 2k-4k resolution for the next 5 years. i will also be using it for multimedia, editing etc. i dont know much about compatibility issues and if this and that is more suitable. and no peripherals. just the tower for now. so please bear with me :) these are the specs i want:
I7 5820K
MSI X99S GAMING 9 AC OR ASUS RAMPAGE V
CORSAIR DOMINATOR PLATINUM 4X8GB DDR4 LOWEST MODEL WITH CORSAIR COOLER
COOLER MASTER EISBERG 120L PRESTIGE
3-4 SAMSUNG 850 PRO 128GB
ASUS ROG RAIDR 240GB PCIE SSD
SEAGATE ST1000DX001 SSHD 1TB 8GB 7200RPM 3.5"
WD BLACK SERIES 4TB 64MB 7200RPM 3.5"
3 GTX 970 ASUS STRIX OR THE MSI ONES
SILVERSTONE RAVEN 1 CASE
EVGA SUPERNOVA 1000 P2 PLATINUM
ASUS 3D BDRW OR LG
CREATIVE LABS ZXR OR ASUS ROG XONAR PHOEBUS (NOT THE SOLO OR ESSENCE)
AEROCOOL TOUCH 2000
WINDOWS 7 ULTIMATE 64
GOTHAM XBMC
BACKTRACK LINUX
SILENT CASE KIT
NEON/LEDS
NEON FANS
DUAL HYBRID INTERNAL TV TUNER
BRAIDED CABLES
LABEL CABLES
THERMAL PASTE KIT
GPU WATERCOOLING KIT?
sorry about the capitals. ive copy paste. thanks again and excuse my bad english.. ^-^
https://linustechtips.com/topic/231173-5000e6300-rig-jan-2015-help/
hi guys. i already did my first post. its really good 2 be here. please help me cuz in a few months ill start buying the parts needed for my futureproof rig. i wanna be able to play all the latest games on (as much as possible) max settings, 2k-4k resolution for the next 5 years. i will also be using it for multimedia, editing etc. i dont know much about compatibility issues and if this and that is more suitable. so plsease bear with me :) these are the specs i want:
I7 5820K
ASUS 3D BDRW OR LG
AEROCOOL TOUCH 2000
GOTHAM XBMC
BACKTRACK LINUX
SILENT CASE KIT
NEON/LEDS
NEON FANS
BRAIDED CABLES
LABEL CABLES
THERMAL PASTE KIT
Location ?
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
Yeah... you really don't need this...
Max settings for 5 years @ 2-4k res isn't going to happen basically no matter how much you spend.
I recommend spending ~2500 if you really have money to waste for no reason, then upgrade the parts in a year or two and re-sell the old parts.
So this is just for gaming? In that case 16Gb of ram will be more than enough. Dont buy the Pcie SSD because with 3 GPU's there might not even be space for it and you'll start running into bandwith limitations i'd imagine. This build is waay overpowered. Current hardware just isn't really made for 4k yet unless you wanna spend insane amounts and theres no point really anyway. Why not do 1440p?
My suggestion would be to spend about 2000 - 2500 on a good soild build and then either upgrade it in 2 -3 years or get a new one at that point.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
save the rest money cause it's too much
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($114.99 @ Newegg)
Thermal Compound: Gelid Solutions GC-Supreme 7g Thermal Paste  ($8.98 @ OutletPC)
Motherboard: MSI X99S GAMING 9 AC EATX LGA2011-3 Motherboard  ($386.10 @ Newegg)
Memory: A-Data XPG Z1 32GB (4 x 8GB) DDR4-2400 Memory  ($555.98 @ Newegg)
Storage: Asus ROG RAIDR 240GB PCI-E Solid State Drive  ($350.98 @ Newegg)
Storage: Seagate  2TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($112.50 @ Amazon)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card (3-Way SLI)  ($569.99 @ Amazon)
Case: Corsair 760T White ATX Full Tower Case  ($174.99 @ NCIX US)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($138.99 @ NCIX US)
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer  ($64.99 @ Newegg)
Monitor: Asus PB287Q 60Hz 28.0" Monitor  ($609.99 @ Amazon)
Sound Card: Asus Xonar Essence STX 24-bit 192 KHz Sound Card  ($179.99 @ Amazon)
Case Fan: Corsair SP140 49.5 CFM 140mm  Fan  ($15.99 @ Amazon)
Keyboard: Razer DeathStalker Essential Wired Gaming Keyboard  ($39.99 @ Newegg)
Mouse: Mad Catz R.A.T. 5 Wired Laser Mouse  ($64.75 @ NCIX US)
Total: $4861.15
Generated by PCPartPicker 2014-10-11 08:53 EDT-0400
thanks for all yr replies guys. yes ive been using pcpartspicker alot. and as i stated its for 2k-4k. i really like the rog swift and i wanna experience that insane specs list it has. i dont mind using 1440p only cuz i realise display port 1.3 isnt out yet.. as  for the parts ill be buying them from overclockers uk, ebay uk, ebay.com, amazon and other sites. i cant buy all the stuff from us only cuz ill be out of my budget. lots of duty and tax etc. no not just gaming. movies,editing, bussiness. the pcie ssd will be ok  i think. the mobo has room for more slots.? and thats the same price i came up with using pcpartspicker. but with these.
i don't know much about custom cooling LOL
actually i was into having aircooling at first cuz i heard alot of ppl messed their rigs with watercooling. but someone told me about sealed water coolers are easier to maintain and more safe to have. otherwise theres no way. i know its a more heated situation with aircooling. but less dangerous for yr rig?
