operating system
Go to solution Solved by IdeaStormer,
hey can someone help me my pc keeping saying windows explorer ran into a problem
Add a "Do Not Run" sign on your desktop, that will keep Explorer from running into problems.
What version of Windows is it? Windows XP?
System specs?
What were you doing when the error occurred?
And as future reference, we CAN NOT HELP YOU WITHOUT DETAILS SO PLEASE PLEASE PLEASE INCLUDE THEM.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/230534-operating-system/#findComment-3154802
We need more info.
Most of the time this will work. DO A SYSTEM RECOVERY!
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/230534-operating-system/#findComment-3154810
System specs?
its windows 8 pro 64bit 4gb ram intel celeron 2.6Ghz and its idling when the error occur
https://linustechtips.com/topic/230534-operating-system/#findComment-3154826
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/230534-operating-system/#findComment-3154888
When was the last time the system was functioning correctly?
#GALAXY
#ATIV
https://linustechtips.com/topic/230534-operating-system/#findComment-3154895
Go into the event viewer and look at shit...   if you need more help let me know
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/230534-operating-system/#findComment-3154926
