Is it normal to see a GTX 780 boost to 1300 on stock clocks and voltage (edit: I should specify by stock I mean 1150mV, not 1100mV seen on reference cards)?
I'm trying to find some information on this, but it seems there is so much variance all over the internet I was wondering what some people on here would say.
I suppose what I'm saying is I find anyone who watches Linus to be a more credible source, lol
https://linustechtips.com/topic/230456-gtx-780-typical-boost-clocks/
Please try overclocking that or give it to k1ngp1n if what you're saying is true.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
that is actually pretty good. try increasing the rest and overckock it higher :D
is it normal ? well its pretty good. mine has trouble boosting on stock to 1.12
Sorry, had to make an edit, it's doing this on 1150mV, not 1100 which would make a difference I suppose.
What are the maximum voltages people are typically running on these (I assume with modified bios)?
Who is k1ngp1n? lel I feel I'm going to be ostracized for asking this.
K|ngp|n is the best overclocker in the industry. Won the world record with a GTX 980 on 2.1GHz
"Instinct or Rationality; Which will you choose? Enchanted by a superiority complex"
"what you do in spite of internet speed is inspiring. :3" From Cae - 2015
I have played with it for a small amount of time this morning; its showing that it is running 1373mhz (boost clock) in valley benchmark on +80mhz, the voltage is at 0.937
To fine your actual max boost clock. Download GPU-Z. Open it up. Select "Sensors." On the GPU Core Clock Drop Down Menu, select "Show Highest Reading." Run Valley or Heaven Benchmark. After the benchmark is completed. Look at the number (in MHz) to the right of GPU Core Clock on GPU-Z. That's your actual max boost clock.
Thats my 780, actually running at 1228 core clock. Valley doesn't read core/boost clock properly.
Intel Core i5 3570K @ 4.5GHz | ASUS P8Z77-V LX2 | 2x4GB kingston hyper-x genesis @1600MHz | Gigabyte windforce GTX 780 3xOC rev.2 | 240GB kingston v300 & 500GB seagate 7200rpm |
Corsair GS600 |  1440p Dell U2515H & 1080p 60Hz tv/monitor | Asetek based AIO 120mm liquid cpu cooler
