Hey guys! So I've been experiencing some networking issues from a week or so. The router I think isn't working properly. I start the router and then as usual, the lights blink for a sec and then the power light goes green, then the LAN light goes green. But I can't connect to the internet. I have a D-Link ADSL 2750u router.
I have some images, I'll show them after posting this thing first, because who knows, I might just get disconnected again.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/229984-problem-with-router/
Wait. EDITING THE POST!
COMING SOON
https://linustechtips.com/topic/229984-problem-with-router/#findComment-3147374
Do all your computers have the same problem of not connecting?
Is this a modem or just a router?
Did your ISP install it/give it to you?
https://linustechtips.com/topic/229984-problem-with-router/#findComment-3147377
1. Try a different computer.
2. If your modem is built into the router and your ISP provided it proceed to step 3. Or If your modem is separate, try turning it off and back on again, if that does not fix anything, check the connections.
3. Try contacting your ISP.
4. If they can do nothing helpful, try having them send someone to come out to take a look at it.
https://linustechtips.com/topic/229984-problem-with-router/#findComment-3147388
