Already posted all my build info here - http://linustechtips.com/main/topic/229640-high-end-micro-atx-build/
Friends recommending that I do not intake air from top and do not pump air out of bottom even though the motherboard is upside down in the case im using ( http://www.aria.co.uk/Products/Components/Cases/Micro+ATX/BitFenix+Phenom+MATX+Cube+Case+-+Midnight+Black+?productId=58069 ), you can probably tell that I think otherwise and think that the intake should be at the top.
Just wondering if I was right or my friends were correct? :D
Thanks guys
https://linustechtips.com/topic/229824-air-flow-question/
Take air in from the front, and exhaust it out the bottom and rear.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/229824-air-flow-question/#findComment-3145172
If I'm not mistaken the front intake uses an indirect airflow. (vents and spacing at the bottom or sides of the case)
As far as which way air should flow... since heat rises, it's better to expel the air near the top, so that the hotter air is pushed out.
You'll want to have the intake in a place that would have cool air coming in, and then you want that air to go through most of the case to help the entire case with fresh cool air.
https://linustechtips.com/topic/229824-air-flow-question/#findComment-3145287
There is no front intake is there, do you mean the top. And thanks for replying :)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/229824-air-flow-question/#findComment-3145294
That MS Paint Skills! FTW!
He is right. You dont want an intake in the lower fan location, dust is evil.
It has 2 120mm fan mounts and the side of the front panel has "air intakes"
https://linustechtips.com/topic/229824-air-flow-question/#findComment-3145362
I'm sure I'm wrong but the front intake is just vents, no fan or anything and most of the front intake air will be taken by the PSU.
Oh, wow that's a crappily designed case. In that case, intake in the rear, exhaust in the bottom.
*mtPaint. Puppy Linux FTW.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/229824-air-flow-question/#findComment-3145371
