So currently i have a single AMD crossfire enabled card, if i got a different better AMD Crossfire enabled card, would that work. Or would i need to get another of the card i have now. Also could i get one AMD card and one NVIDIA card, or will that not work?
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/229729-will-2-cards-not-the-same-work/
"Single AMD crossfire enabled card". I think you mean to say that the card can crossfire because crossfire can not be enabled with a single card as far as I know. As for the rules for SLI/Crossfire watch this
https://www.youtube.com/watch?v=pGN1na3F5do
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
What is your current card? Also no you can't mix AMD and nvidia cards
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
If you run an old Nvidia driver you can use it as a dedicated PhysX card but it wont talk with the AMD card.
and as far as mixing AMD cards it's became a little more difficult to figure out with the name change from 7xxx to R X XXX, I wish I could help you on that but the short answer is maybe, what cards are we looking at?
Long answer:
AMD Radeon R9 290X CrossFire compatible with AMD Radeon R9 290X and R9 290
AMD Radeon R9 280X CrossFire compatible with AMD Radeon R9 280X, R9 280, AMD Radeon HD 7970, and HD 7950.
AMD Radeon R9 270X CrossFire compatible with AMD Radeon R9 270X, AMD Radeon HD 7870 and AMD Radeon 7850.
AMD Radeon R9 270 CrossFire compatible with AMD Radeon R9 270.
AMD Radeon R7 260X CrossFire compatible with AMD Radeon R7 260X and AMD Radeon HD 7790.
AMD Radeon R7 260 CrossFire compatible with AMD Radeon R7 260.
AMD Radeon R7 250 CrossFire compatible with AMD Radeon R7 250.
AMD Radeon R7 240 CrossFire compatible with AMD Radeon R7 240.
Crossfire cards will downclock the the weakest cards specs.
Why do you always die right after I fix you?
It will work for rendering but I don't think it would work for gaming unless you set physx to it
Well how would i set physx up
Obligatory PC specs
DO NOT POST SPAM!
in the nvidia control panel also it would only work with an nvidia card and its going to help very little and only in certain games like metro
Long answer:
Damnit my card wont work for the other one i would want.  BTW nice computer :)
Obligatory PC specs
DO NOT POST SPAM!
