Can the graphics card get hurt or something negative happen to it if I hypothetically had the fan speed on 70%-100% all the time or is it just louder noise but it's physically ok?
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/229564-fan-speed/
Might wear out the bearings more quickly
"Rawr XD"
https://linustechtips.com/topic/229564-fan-speed/#findComment-3141960
graphics card will be fine, just fan wont last as long
if your temps are fine idk why would you be running at such high rpm
I don't, I was just wondering.
I don't mind extra noise so if it wouldn't have too much of negative downsides I wouldn't mind doing it.
But if the gpu fan is going to wear out faster it doesn't sound worth it.
I plan on using the computer on and off for 3-5 years.
So hard finding time for gaming when going to school QQ
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3144409
Fans will be fine, but are there any upsides to running them at high RPMs all the time?
https://linustechtips.com/topic/229564-fan-speed/#findComment-3144432
Maybe lower VRM temps? It would keep the card cooler... Maybe find a fan speed that dosnt return reduced temperature any more (100% might be similar to 80% regarding load temps) and create a custom fan profile to hit this speed once it hits gaming temps.
That way your not wasting the fan life Cooling an idling card
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/229564-fan-speed/#findComment-3144805
Lower temp but if it reduces life length because of fan efficiency going down then it's not worth it.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3148968
I already have custom fan profile.
Da fuq is VRM?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3149005
Voltage Regulator Module.
Da fuq is Voltage Regulator Module then?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3149456
And what advantage is lower temps (when temps are already low enough)?
BTW, VRMs regulate the voltage coming in to be within a specific voltage range without too much ripple. You have the same things on your motherboard around the CPU socket (underneath the heatsink)
https://linustechtips.com/topic/229564-fan-speed/#findComment-3150411
I didn't say they are low enough or how much my temps were.
I wouldn't mind lowering temps with 5-10 degrees while idle and 10-20 degrees while gaming.
So what am I supposed to do with a/the VRM?
If it's on some auto mode then I shouldn't need to mess with things. I don't see what he/you mean.
Apply better thermal paste or what?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3151261
Don't mind the VRMs. They're fine.
Again, what's the point with lowering the temps? What benefit do you get from it? It won't make it perform better (assuming you're not hitting critical temperature)
https://linustechtips.com/topic/229564-fan-speed/#findComment-3151351
It's mostly a placebo effect I think. But ca 30 degrees idle and 60 gaming temp wouldn't be too bad :P
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/229564-fan-speed/#findComment-3155739
