Ok so I just won an auction for a GTX 580 for 80.-. I put this bid in fairly early thinking i wouldn't win since they usually go for more. Should i keep it or try to sell it again... Just realized that i dont actually have any use for it (i barely ever play games) :P
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/229178-should-i-keep-it/
Depends, what card are you running right now?
Sell the 580 and your current card and buy a new one with the money :D
my current card... dont think i can sell that lol
123
https://linustechtips.com/topic/229178-should-i-keep-it/#findComment-3136686
Why were you bidding on a card you dont really want?
I would keep it and replace your current GPU.
https://linustechtips.com/topic/229178-should-i-keep-it/#findComment-3136741
I thought i wanted it and then realized that i dont really need it.. call it dumbassery ;)
https://linustechtips.com/topic/229178-should-i-keep-it/#findComment-3136765
Replace current one if its better
CPU: R9 5900X----GPU: RX 7900 XTX ------MOBO: ROG X570E-------RAM: CORSAIR VENGANCE 32GB-------PSU: SEASONIC 1000W-------CASE: LIAN LI O11D XL ROG
https://linustechtips.com/topic/229178-should-i-keep-it/#findComment-3136788
Fair enough. We are all guilty of it at some point.
https://linustechtips.com/topic/229178-should-i-keep-it/#findComment-3136808
