Hypothetical Build - Need Feedback
Go to solution Solved by Guest,
1. 8gb is fine dont bother with 16.
2. Get a bigger ssd if you want to use it as primary storage
3. Get a evga g2 PSU
4. GPU is great but stretch for the 780ti if you can ;)
Hello all! I need feedback on the below build. I have already purchased a Cooler Master N600 with window, so I am limited to that.
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($97.16 @ Amazon)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($137.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($86.54 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($349.99 @ Amazon)
Optical Drive: LG GH24NS90 DVD/CD Writer  ($19.98 @ OutletPC)
Total: $1161.62
Generated by PCPartPicker 2014-10-06 18:03 EDT-0400
Thanks!
Smith
P.S. Check out my poll
https://linustechtips.com/topic/228726-hypothetical-build-need-feedback/
my planned rig is so similar to this lmao, great build. bit overkill on the psu :P 4690k + 970 isnt even over 400 watts afaik :D
Looks pree darn good!! if you arn't editing and rendering probably go with 8gb of ram? unless you really feel you need 16
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
Thanks for the feedback. Had a feeling that the PSU was overkill. Is a 500 watt PSU good? I am planning to OC CPU. Also updated "primary storage" to "boot disk"
Welcome to the forum! This build is pretty good, however 8GB memory is good enough if you're just gaming. And you can get a lower wattage power supply like the CS550M, PCPartPicker has a good calculator for that.
LTT's unofficial Windows activation expert.
I am planning to game and edit my videos using Premiere Pro. And thanks!
  • 4 weeks later...
