i have just attempted to build my rig yaaay waited 5 months to build it and i have just realised that at the top of my mobo says eatx 12v but the pins dont line up :( i have a corsair 750m psu and a asus sabertooth 990fx :(
Amd fx 8350,asus sabertooth R2,corsair c70,corsair h100i,palit gtx 580,corsair 8gb vengeance Ram,corsair txm 750.
https://linustechtips.com/topic/22859-mobo-cpu-cable/
The 8-pin CPU connctor should be a propartery connector that fits universally. Are you sure you have it turned the right way around? And that your not trying to fit a PCI-e 8-pin into the 8-pin CPU connctor?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/22859-mobo-cpu-cable/#findComment-289151
Yeah. Make sure you have it turned the right way, and that it's even the right plug. PCI-E power and CPU power plugs are similar.
https://linustechtips.com/topic/22859-mobo-cpu-cable/#findComment-289157
Ok a cpu cable is either an 8 block or two sets of 4 that go together. You need to make sure the one you have says cpu on it and is one of those types and if it is a 4+ 4 then make sure all of the pins go in correct by inserting 4 pins at a time rather than all of the 4+4 together at once. Also e-atx power is just what it is cooled. i  have a m-atx am3 board from asus that says this on the 24 pin and it is perfectly fine. I think some manufactures just call it different things.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/22859-mobo-cpu-cable/#findComment-289251
