How to get rid of buzzing noise from HD558
creativename
I plugged my HD558 into my monitor, and then I use Nvidia's driver to use my monitor as the audio output, but when nothing is playing the headphone makes buzzing noises. How do I get rid of it. What is the buzzing noise?
Same thing happens when I plug it into a sound card or the onboard sound.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
That's called noise.
Plug the headphones directly into the motherboard and see if that stops it.
