I've completed 3 projects worth around 40k each but only got 10.5k points
passkey is fine from what i can see
any ideas?
[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
https://linustechtips.com/topic/228386-problem-with-points/
Happens on and off, seems to be to random users, I've had it happen a few times, then it corrects itself.
I've also noticed today that Kakao Stats was having issues updating scores aswell.
any ideas?
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/228386-problem-with-points/#findComment-3127115
If you actually go through your logs, you will see exactly how much you got rewarded with. If this was in the past few days, there are a lot of issues going on with the systems at FAH right now, so I don't expect the stats to be properly updating as well.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/228386-problem-with-points/#findComment-3129571
Okay, thanks for the update guys. I'm just getting back into folding after a while. It gets too hot to fold in the summer.
https://linustechtips.com/topic/228386-problem-with-points/#findComment-3132086
not really worth starting a new thread, but stat servers may be borked right now, so if anyone isn't seeing their points updating since last night, its not your client. https://foldingforum.org/viewtopic.php?f=18&t=26191&start=165
LTT stats page confirms as much:
LinusTechTips_Team
Report generated on 15:57:06 October 08, 2014
Date of last work unit 2014-10-07 14:05:31
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/228386-problem-with-points/#findComment-3141572
*edit* Kakao stats are up and running again.
Just in case others look at Kakao stats from time to time like I do, and wondering why its down.
http://forum.kakaostats.com/index.php/topic,1107.30.html
Kakao: Right now I have no land connection at all. It can take some time to fix.
https://linustechtips.com/topic/228386-problem-with-points/#findComment-3177046
