Fan hub.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/228275-help/#findComment-3124966
i can find up to 6 fan ones but no more
and also what kind of mobo can handle like 10-15 fans?
None that I know of honestly.
https://linustechtips.com/topic/228275-help/#findComment-3125004
and what would be a good power supply for that an i-5 and a 270x or maybe 280x
600 watts should do you good. If you're on a budget, the Corsair CX600 is a good choice. Don't know any others on the top of my head.
https://linustechtips.com/topic/228275-help/#findComment-3125040
the NZXT Grid has up to ten fans.. http://www.nzxt.com/product/detail/123-grid-fan-hub
"We hold these truths to be self evident, that all men are created equal, that they are endowed by their creator with certain unalienable rights"
https://linustechtips.com/topic/228275-help/#findComment-3125203
