I'm having a small issue with a program from school. I need to use a nested for loop (A for loop inside another) to output the following.
Any help is greatly appreciated :D
                                           1
                                   1       2     1
                            1     2       4     2     1
                     1     2     4        8    4     2     1
               1    2     4     8      16    8     4     2    1
          1   2    4     8    16     32   16    8     4    2   1
     1   2   4    8    16   32     64   32   16    8    4   2   1
1   2   4   8   16   32   64   128   64   32   16   8   4   2   1
https://linustechtips.com/topic/228211-java-nest-for-loop-help/
@SlaughterApollo
This will print half of the triangle.
int numberOfLines = 8; //based on the image you postedif(numberOfLines >= 1){    for(int spaces=0; spaces < numberOfLines; spaces++){        System.out.print(" ");    }    System.out.print("1");    for(int spaces=0; spaces < numberOfLines; spaces++){       System.out.print(" ");    }    System.out.println();}for(int i=1; i<numberOfLines ; i++){    for(int k=0; k<numberOfLines-i-1; k++){        System.out.print(" ");    }     for(int j=1; j<=(Math.pow(2, i)) ; j*=2){        System.out.print(j + " ");     }    System.out.println();}
        1              1 2      1 2 4     1 2 4 8    1 2 4 8 16   1 2 4 8 16 32  1 2 4 8 16 32 64 1 2 4 8 16 32 64 128
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3124252
@SlaughterApollo
This will print half of the triangle without the preceding spaces.
int numberOfLines = 8; //based on the image you postedif (numberOfLines >=1) System.out.println("1"); for(int i=1; i<numberOfLines ; i++){      for(int j=1; j<=(Math.pow(2, i)) ; j*=2){          System.out.print(j + " ");       }       System.out.println();}
Output:11 2 1 2 4 1 2 4 8 1 2 4 8 16 1 2 4 8 16 32 1 2 4 8 16 32 64 1 2 4 8 16 32 64 128
i got the math but the spacing is messing me up
public class Chp4_19 {	public static void main(String[] args) {		for(int x = 0; x < 8; x++)		{		for(int y = 8 - x; y> 0; y--)		{		System.out.print(" ");		}		int w = 1;		for(int z = 0; z < x; z++)		{		System.out.print(w + " ");		w = w * 2;		}		while(w>0)		{		System.out.print(w + " ");		w = w / 2;		}		System.out.println();		}	}}
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3124313
Add an extra space to the print statement on line 9, that fixes the spacing until double digit numbers come into play, so once you get a double digit number you have to reduce the spacing by one.
int w = 1;
if(w<10){
w = w * 2;
else if(w<100){
w = w * 2;
else{
w = w * 2;
while(w>0)
if(w<10){
w = w / 2;
else if(w<100){
w = w / 2;
else{
w = w / 2;
PSU Tier List | CoC
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3124438
Something like this?
/** * Created by Tyler on 2014/10/05. */public class Test {    private static final int POWER_COUNT = 8;    private static final int MAX_SPACING = getNumberOfDigits(Math.pow(2, POWER_COUNT));    public static void main(final String... args) {        for (int line = 0; line < POWER_COUNT; line++) {            for(int i = line - POWER_COUNT + 1; i < line; i++) {                if (i >= 0) {                    print((int) Math.pow(2, i));                } else {                    print(null);                }            }            print((int) Math.pow(2, line));            for(int i = line - 1; i > line - POWER_COUNT; i--) {                if (i >= 0) {                    print((int) Math.pow(2, i));                } else {                    print(null);                }            }            System.out.println();        }    }    private static void print(Integer num) {        if (num == null) {            for (int i = 0; i < MAX_SPACING+1; i++) {                System.out.print(" ");            }        } else {            int numSize = getNumberOfDigits(num);            System.out.print(" " + num);            for (int i = 0; i < MAX_SPACING - numSize; i++) {                System.out.print(" ");            }        }    }    private static int getNumberOfDigits(double num) {        return (int) (Math.log10(num)) + 1;    }}
Output
                             1                                                       1   2   1                                               1   2   4   2   1                                       1   2   4   8   4   2   1                               1   2   4   8   16  8   4   2   1                       1   2   4   8   16  32  16  8   4   2   1               1   2   4   8   16  32  64  32  16  8   4   2   1       1   2   4   8   16  32  64  128 64  32  16  8   4   2   1
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3124950
Output
Clearly thats perfect but if i turned that in i would get cut for cheating by my teacher lol
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3125026
Output
Asking for help is not cheating lol, as long as you understood what happened.
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3125037
the whitespace can be simply handled with tabs
import java.io.*;class pyramid{	private static final int ROWS = 8;	private static int power(int number, int exp){			int res = 1;			while(exp-- > 0)					res *= number;			return res;	}	public static void main(String[] args){			for(int i = 1; i <= ROWS; i++){					int j, blanks = ROWS - i;					for(j = 0; j < blanks; j++)							System.out.print("\t");					int max = power(2, i - 1);					for(j = 1; j <= max; j *= 2)							System.out.print(j + "\t");					for(j = j / 4; j > 0; j /= 2)							System.out.print(j + "\t");					System.out.println();			}	}}
https://linustechtips.com/topic/228211-java-nest-for-loop-help/#findComment-3126623
