My friend wants to join the PC Master Race but with a budget of $1000 CAD after tax (13%), and he needs a monitor, keyboard (does not need mechanical), mouse and audio.
The most demanding game he plays is BF3 (he's fine with medium settings) and a lot of Minecraft. He does not care about brands or anything like that. (Not a fanboy)
He does not want to overclock.
This is the build I made for him.
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($122.01 @ DirectCanada)
Motherboard: Asus M5A78L-M LX PLUS Micro ATX AM3+ Motherboard  ($61.09 @ DirectCanada)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($100.87 @ Newegg Canada)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card  ($172.08 @ NCIX)
Case: Rosewill Line-M MicroATX Mini Tower Case  ($71.47 @ Newegg Canada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($47.13 @ NCIX)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($112.76 @ DirectCanada)
Monitor: AOC E2425SWD 60Hz 24.0" Monitor  ($146.88 @ Canada Computers)
Total: $936.83
What would you change? Thanks.
https://linustechtips.com/topic/228034-build-plan-for-friend/
for better performance change the GPU to something like
http://ca.pcpartpicker.com/part/asus-video-card-r9270xdc2t2gd5
it may pop up the price but it should be still within the 1K CAD budget & there's that AMD Never Settle Space Bundle for them free games
Laptop
MSI GS65 Stealth 8SF
Intel Core i7 8750H, Kingston Hyper X Impact 32GB (2x16GB) SODIMM DDR4 2666Mhz RAM (Ugraded from 1x16GB SODIMM DDR4 2666Mhz), Western Digital PC SN 720 512GB NVME SSD & Adata XPG SX8200 1TB NVME SSD, Nvidia RTX2070 Max Q, 15.6" 1920x1080 144Hz
Screen | Keyboard | Mouse
Dell U2718Q 3840 x 2160 60Hz, Sony KD-438300X 3840x2160 TV | HP EliteDisplay E273q 2560x1440 60Hz
Corsair K70 Rapidfire Cherry MX Speed RGB LED | Corsair K70 Vengeance Cherry MX Brown Red LED
Logitech MX Master 2S | Roccat Kone XTD
Phones
Daily Use: Sony Xperia 1 II | Back Up: Sony Xperia Z5 Premium
Audio
IEM: Sony XBA-Z5, XBA-A3, WF-1000XM3
Headphones: Audio Technica ATH-M50x-BT & ATH-SR50-BT, Sennheiser x Massdrop HD6XX (with Antlion Mod Mic), Sony WH-1000XM4
Consoles
Nintendo DSI, 3DS, Switch, Sony PlayStation 4 Slim
Networking
Asus RT-AX86U | RT-AX82U | RT-AX55 (Asus AI Mesh)
https://linustechtips.com/topic/228034-build-plan-for-friend/#findComment-3121901
overclocked RAM is a big waste if your not going for some high performance grade machine, you could go for something cheaper and shave 20~30 off. Also the same as DenzelFenzel mentioned. Upping the GPU a little bit might give get him something he didnt even know he wanted. 270x is a good pick, or you can check out a 760 or even 770 on some sites, the GTX price drop has knocked a few higher end cards into your price range
https://linustechtips.com/topic/228034-build-plan-for-friend/#findComment-3121943
