How many fans?
Go to solution Solved by _ASSASSIN_,
you can always use this, all you need is just one 3 pin on your motherboard
http://www.swiftech.com/8-WayPWMsplitter.aspx
Hey everyone :)
As I've said in some of my previous topics, I'm a n00b when it comes to computer hardware.
I currently have this motherboard: http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dp67de.html
And I was wondering if I could connected any other coolers to this Mobo other than the CPU, rear and front? What I would like is having 2x140mm fans blowing cold air down to my GPU ( From the top of my Pc-case) . But I really don't know if my Mobo supports more than those 3 ( CPU, rear & front fans ).
I hope some of your Tech-nerds out there can help me out :)
Now I've tried to make some research on my own, trying to figure out this by myself, other than posting a thread right away saying " I NEED HELP PLOX" so that I wont seem like an unknowing douchebag :S
Regards,
Eladarian.
https://linustechtips.com/topic/22777-how-many-fans/
A fan controller would be an option for you. Like ASSASSIN said a could option is the fan controller from Swiftec that uses a molex and allows up to 8 fans to be controlled from one pwm slot on the motherboard. Great if you want fans to be controlled in  groups.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/22777-how-many-fans/#findComment-288074
Information from the official product guide:
Fan Headers
The function/operation of the fans is as follows:
• The fans are on when the board is in the ACPI S0 state.
• The fans are off when the computer is in the ACPI S3, S4, or S5 state.
• Each fan header is wired to a tachometer input.
• All fan headers support closed-loop fan control that can adjust the fan speed or
switch the fan on or off as needed.
• All fan headers have a +12 V DC connection (up to 12 V DC when using 3-wire
chassis fans).
• All fan headers are controlled by Pulse Width Modulation.
• The chassis fan header supports linear fan control on 3-wire fans.
The Desktop Board has a 4-pin processor fan header and two 4-pin chassis fan
headers compatible with 4-wire and 3-wire chassis fans.
So you have 3 4-pin fan headers available. As for having cold air blowing from the top, I advise against that. Ideally you'd want cold air coming from the front, and heat exhausting out of the top or back of the case, since heat rises naturally. You also want positive air pressure (more air coming in than out of the case) if you want to keep dust buildup down.
To have more than 3 fans controlled individually, you'll have to use fan splitter adapters or a fan controller.
https://linustechtips.com/topic/22777-how-many-fans/#findComment-288076
The case I have is The Fractal Design Define r4, which supports 2x120/140mm at front, 1x120/140mm rear and 2x120/140mm top :)
Alright.  I'd set it up as 2x 120/140 in the front, and 1x 120/140 exhaust, and leave the covers on the top two vents to help with dust collection.  Use a fan splitter cable for the two front fans so they can be used from a single header.
https://linustechtips.com/topic/22777-how-many-fans/#findComment-288120
I have an R4 define,
I run 4 fans 2 front intake, 1 back and 1 top exhaust....
With the R4 you can connect 3 fans to the fan controller, i personally only run the 2 exhausts off the fan controller. I use a couple of PWN arctic fans for front intake off one of my motherboard connectors.
Looking at the quick guide to your motherboard it seems you have 3 4 pin fan connectors.
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/22777-how-many-fans/#findComment-288222
the controller at the front runs independently, it doesn't need to be plugged in anywhere on the motherboard you just connect a molex power connector from your PSU to the controller, there are 3 cables coming off it, plug the fans directly into them and it will work.
https://linustechtips.com/topic/22777-how-many-fans/#findComment-288431
Also, I noticed that there's some sort of connectors coming out from that control-panel, can you just plug the fans into those, and control the fan speed from there? That would be neat o0!
https://linustechtips.com/topic/22777-how-many-fans/#findComment-289052
yes, using the switch on the front top right of the case...
https://linustechtips.com/topic/22777-how-many-fans/#findComment-289179
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/22777-how-many-fans/#findComment-289196
Pretty sure the 4th pin is what controls the speed for PWM fans.
yeah, I know that, I'm not an idiot, as both asus and gigabyte have both implemented ways to control both 3 and 4 pin fans.
with this it's different though, if you put it into the CPU fan header, it will control all of them (fans put into the splitter)
https://linustechtips.com/topic/22777-how-many-fans/#findComment-296875
