Difference between SP120 Static Pressure and SP120 LED ?
Solved by DIV1D3,
One set has LEDs, and the other doesn't??
I'll check back with the CFM, dBA and static pressure.
Edit:
The ones without the LEDs just have a higher RPM, which affects the CFM, mmH20 and audibility.
If you have a rad that you are placing these fans on or in a restricted environment, then the ones without the LEDs will be ale to move more air, but with no restricts, or with very little restriction than an AF fan would be better.
SP120 High Performance:
- 62.7 CFM
- 3.1 mmH20
- 35 dBA
- 2350 RPM
- 0.18 A
SP120 LED:
- 57.2 CFM
- 1.46 mmH20
- 26.4 dBA
- 1650 RPM
- 0.26 A
