Hello can someone help me. I have very low budget and i have to save money for a preety long time to get something so i upgrade only when something breakes on me or becomes preety outdated and when i do upgrade i aim at something "better" so that i dont have to replace it any time soon. I currently have radeon hd 5570 gpu i plan to upgrade it to gtx 770 or hd 7970. My question is will it be bottlenecked by my triplecore amd athlon II X3 440, 3000mhz procesor. Ofcourse i plan to upgrade it but it will take me a long time because il have to upgrade my motherboard and power supply + procesor at the same time and i want to get a full hd monitor because my current one is 1680x1050 WITH DAMN VGA -.-'. Sorry for bad English im European :P
https://linustechtips.com/topic/22729-bottleneck-if-yes-how-much/
firstly what is your psu? secondly is your cpu overcloecked?
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/22729-bottleneck-if-yes-how-much/#findComment-287446
You may not be able to run the 700 series. They need a high ampage on the 12v rail. Post your full system specs please, with HDDs and everything so we can see what sort of power you are drawing first.
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
https://linustechtips.com/topic/22729-bottleneck-if-yes-how-much/#findComment-287453
i think that psu is fine but there would be a bottleneck and that would be your cpu while its stock. i would oc as much as you can while still being stable. the more you oc the less of a bottleneck you will have
https://linustechtips.com/topic/22729-bottleneck-if-yes-how-much/#findComment-287476
i think the Athlon II x2 3000mhz  it is a bottleneck, and a Athlon II x4 3000mhz "is not" a bottleneck
so "you may be good there" with your Athlon II x3 3000mhz
i think you will fine with that 7970 (or a 7950) and that 600w PSU
for the 770 you may be ned a new PSU, not sure really
APU = A10
https://linustechtips.com/topic/22729-bottleneck-if-yes-how-much/#findComment-287488
