wood%20textures%20asus%20logos%20rog%20r
www.clarkeac.blogspot.com
Started my desktop computer this week. I have the mobo, PSU, graphics card and SSD (coming soon) and have yet to get the CPU + Water cooler and the RAM.
This computer was intended for pretty much everything except extreme gaming however, I have planned to expand my component selection to include that factor. This isn't much of a mod but more of a first timer experiment so we'll see how it goes!
Choose an NZXT case. It looks REALLY good, BUT, it does NOT come with a optical drive slot. I was an idiot and didn't look but alas there is none. Not much of a problem since I download everything online anyway but nevertheless, keep that in mind.
The PSU came with pre-sleeved cables which was great because it doesn't void the warranty but they only come in black. Not much of a problem since my color scheme was black/red.IMG_4922.JPG
Picked up the Graphics card for $70 off, been used for 2 months. IMG_20141003_112107250.jpg
This is what I've got up to this point. I'm expecting to have the build completed by February and hopefully sooner.
https://linustechtips.com/topic/226919-first-build-in-progress/
70$ off? bargin, so you payed like 70$ ?
how much did you save on other components?
Ha, the card is definitely not top of the line, but we overclocked it to 1400+ and it handles everything I've thrown at it 3DMark 11 60FPS+ no problem. Nothing on the other components.
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3108031
That is going to be beautiful. Enjoy!
CPU: i5 2500k@4.2 MBO: Asrock P67 Extreme4 GPU: Gigabyte GTX 560Ti 1GB RAM: Corsair 8GB 1600 SSD: Samsung 840 Basic 250 HDD: Samsung F3 1TB + WD 2TB Green + WD MyBook 1TB external; ODD: LG BD/DVDRW; PSU: Corsair TX 650
Case: Fractal Define R3 Black Pearl; Mouse/Keyboard Logitech Performance MX + Wireless K800; Monitor: Dell U2311H
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3108064
UPDATE 10/6/14 - Custom Paint Jobs
Did a little bit of custom painting over the weekend. This is the back plate on my Graphics card.
As you can see I tried to paint the SSD but because I used a paper mask, it smudged so
NOTE: DO NOT USE PAPER AS A MASK!
I will be redoing it with foam cutouts.
Check out my blog for additional pics: www.clarkeac.blogspot.com
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3127719
Looks pretty nice. I'd just use plain masking tape as a mask and do cutouts with a razor blade.
Although yeah, that runs the risk of scratching shit.
Dubs are better than subs
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3127733
That's a great idea and I can't believe I didn't think of it as I have done paint jobs like that before. I think it was because I printed off an image and cut that  out. Thanks
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3127750
No problem.
https://linustechtips.com/topic/226919-first-build-in-progress/#findComment-3127785
