What is the nvidia equivalent of the radeon 7950 850MHz?
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/22659-radeon-7950/
I think a 660 but im not 100%sure i know pricing they are usually in the same bracket. but the 7950 is kind of the best card for the money on AMDs side
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/22659-radeon-7950/#findComment-286608
It depends on what country you're in.. where are you from? The price brackets change signifcantly dependant on import costs ect.. Theres no clear answer really, its all dependant on how much you can source them from lol.
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
https://linustechtips.com/topic/22659-radeon-7950/#findComment-286633
I think a 660 is more <7870.
In terms of 7950 it's more like >gtx770?
...770>7970Ghz>680>7950>(670)660Ti>7870>660
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/22659-radeon-7950/#findComment-286635
Woops sorry that's what I kind meant! I put the arrow the wrong way :D I was trying to say that the 7950 is slower than the gtx 770.
Is this the real life? Or is this just fantasy?
https://linustechtips.com/topic/22659-radeon-7950/#findComment-286668
If you factor in overclocking I would say
780>7970>GTX770/680>7950>670/660ti>7870>660/7850>650 Ti boost
Ok, agreed :)
https://linustechtips.com/topic/22659-radeon-7950/#findComment-286713
