Im trying to figure out how im going to set up all my audio devices and switch between them. I just ordered the Kanto Yumi speakers off of massdrop and also have a Schitt stack (Modi DAC and Magni amp) and beyerdynamic DT 990 Pros. Im debating buying a switcher to switch between headphones and speakers so that Yumis come out of the DAC and the headphone amp also Comes out of the Dac (this would clutter up my desk most likely). Or I could run an optical audio cable from my PC to the Yumi's but then I dont make use of my DAC which is probably better :(
Any thoughts?
Audio cable - http://www.amazon.com/gp/product/B001TH7GSW/ref=ox_sc_sfl_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Switch - http://www.amazon.com/gp/product/B00J6W8D0C/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A2HRXDCK7SIH44
https://linustechtips.com/topic/226584-audio-setup/
get a switch, and get a decent switch, a cheap switch will just degrade your sound, which then makes no use of actually using DACs
I don't think it will degrade the sound, unless the switch is horrendously designed.
Here is the switch I use: http://www.amazon.com/gp/product/B005TE7GP4/
RCA can be converted into 3.5mm, quarter inch can be converted in to 3.5mm. I use a quarter inch to 3.5mm converter that has a little cord and is right angled to cut down on clutter on my desk.
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
https://linustechtips.com/topic/226584-audio-setup/#findComment-3104393
Meh, $5 switch FTW.... B)
https://linustechtips.com/topic/226584-audio-setup/#findComment-3107396
http://www.amazon.com/gp/product/B0001F347K/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Get this. I run my PC out to my DAC then into the switcher with then goes to my amp, powered speakers, DJ controller and 3.5mm jack if I need to plug my phone in for some reason, It's really easy to set up and use.
My compooter: http://imgur.com/a/mDFsx?
https://linustechtips.com/topic/226584-audio-setup/#findComment-3109735
That looks pretty useful actually. So you can use any port as input and output? Theres no dedicated input or output?
https://linustechtips.com/topic/226584-audio-setup/#findComment-3110157
