Hello,
I have a msi Z87 G45 motherboard with the 4670k with a stock cooler, 8gb hyper x, HD 7950 XFX DD.
When I play demanding games, like BF3 on ultra, I get to play the game for 1-2mins then my PC crashes (screen turns black) and the GPU fans and CPU fans make loud noises (like at max) I tired it in the case, out the case, with 2 different PSUs, Thermal take TR2 700 watt, and some cooler master 550 watt 80+ that I have atm.I don't understand this issue... It works fine on games like CS GO and BF3 on low...
Please help, I'm new to PC gaming.
Thanks all!
https://linustechtips.com/topic/226479-pc-shuts-down-randomly-please-help/
Hello,
Thanks all!
Check your temps when you launch the game, it sounds like something is overheating big time. Or you have a bad video driver.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
Check windows event viewer and it will tell you why the PC shut off.
What version are your AMD gpu drivers?
Case: Phanteks Enthoo Pro | PSU: Enermax Revolution87+ 850W | Motherboard: MSI Z97 MPOWER MAX AC | GPU 1: MSI R9 290X Lightning | CPU: Intel Core i7 4790k | SSD: Samsung SM951 128GB M.2 | HDDs: 2x 3TB WD Black (RAID1) | CPU Cooler: Silverstone Heligon HE01 | RAM: 4 x 4GB Team Group 1600Mhz
Used 14.4 now going to test 14.9.
Just a little out of date  :D
Yeah, try updating the drivers are see if that does it.
EDIT: Also, what version of Windows are you on?
i changed the driver and its still fucking up it makes less noise when it crashes and it restarts now instead of the old blank black dead screen RIP computer 2014-2014
How?
google it...
its really simple and it tells you WHY it turned off.
As Enderman suggested you should check in the event viewer and maybe post a screenshot of it.
EDIT: Try COMPLETELY removing the GPU drivers using this utility: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Then try installing 14.9 drivers again.
Is the GPU overclocked? If so place GPU to stock speeds, and set power limit to +20%
Then run Unigine Heaven benchmark
If the GPU can not complete the benchmark twice in a row then RMA the GPU. Tell them exactly at which frame the benchmark crashes at. XFX use that in their own in house testing.
Oh and make sure that both GPU power connectors are using individual cables and not chained together.
