I have had a black widow for 2 years now with the loud green switches. i saw that the new k95 keyboard came out and would like to get it. I have narrowed the decision down to the k95 in brown and the k95 in red. I have seen the sample switch kits that have the black brown red and blue switches to test but realize that the blues are just like the greens, the blakcs are less common. I don't really want to spend $20 to press 2 buttons...  ^_^
I know it is all personal preference, and I am starting to lean towards the browns more than the reds, since I am coming from green switches. Would you agree with this? What would be your recommendation?
Thanks!
https://linustechtips.com/topic/226012-brown-switch-or-red-switch/
I'd say browns. If you have greens now, the browns will be like pressing through tactile butter for you. Thew reds will be like air.
I like my browns because they are still nice to type while being snappy enough in games.
who cares...
Only the blackwidow of this year (2015?) has the chinese "Razer green" switches. You're likely using cherry MX Blues as razer has never used MX Greens.
I use MX Browns now and was coming from a Blackwidow Ultimate 2012 w/ MX Blues similar to you. I can say that I rather the MX Browns over the Blues for for gaming/typing (although MX Blues were very good for typing, not the greatest when gaming). I think that the tactile bump that the MX Browns will be a better fit if you liked the feel of your MX Blues as MX Reds are linear switches and will not be comparable to your MX Blues.
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
Reds have less of a tactile feel and feel more like one up/down movement. Browns have a discernable "click" when they bottom out and are a good hybrid key. I chose browns after testing out greens, blues, browns, n reds. I found with reds I would bump into keys lightly by accident and they would still register.
Thanks!
I have browns, and they're basically blues, but only slightly quieter. The difference can be heard here, about the middle of the page.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
Thanks everyone!
I tried going to bestbuy, staples, walmart, target, etc... and surprisingly none of the stores had any red or brown switches to test. I think I will be going with the browns because I think the reds will be to light for me. Thanks for all the advice!  :D
Browns are like blue's except not at all.  Brown's are a light tactile switch without a click.  Browns are 5cn below blues in force and they're quiet.  Red's are really linear and you can't feel the depression point, but man can you double tap and press keys easy.  I started out with Buckling Springs, then membrane(was horrible) and then went to Browns, after browns I jumped to MX Green's(Not the greens you are talking about as the ones you have aren't greens, but blues if they're from a BW from years ago), MX greens are my favorite tactile switch to date - 80cn to accentuate and 120 for full depression, they're heavier than buckling and freakin' glorious, but not available on Corsair, and then I tried blue's and Blue's are--yeah.  Super light compared to MX Green's, blue's are heavier than brown as you're aware and they're clicky, but I say if you're mainly going with Corsair - go for browns, they're good if you don't like click.  If your'e willing to give up the lighting effects and try other stuff - WASD Code keyboards are amazing with MX Clear's.  My favourite flavour of switch now 8)  So, if you're going Corsair - browns.  Otherwise, WASD, CM-storm, Max keyboard, or Ducky.  MX Clear switches are stiffer browns and I swear just amazing.  xP
Are you sure the black widow ultimate has blue switches??? When I take the keycaps off the switches are green...
Positive.  The old Blackwidows from 2 years ago use Blue's.  The Green switches / Razer Kalih switches only came out this year, so the one you have either has discolored switches or you may have slight colorblindness xP(No offense on that).  Also as for O-rings, they are meant to shorten the key-travel distance and dampen sound.  I used them on my old k70 mx blue, and it's a much faster typing experience, but not for everyone.  I personally like the normal typing compared to O-rings.
I miss-spoke...
I have the 2014 ultimate keyboard
http://www.custompcreview.com/reviews/razer-blackwidow-ultimate-2014-green-switches-review/20406/2/
I got it when it was first released so it seemed like 2013...
I miss-spoke...
Then those are vaguely similar to Kalih blues which are a knockoff of Cherry MX Blues. You'll be better off with MX Browns if you enjoy the bump (not the audible click) of your BWU. If you don't like the tactile bump (again, not the audible click), then reds are for you. Other than that browns and reds are quite similar on the spec sheet (45g actuation force).
xoxo samantha <3
All the cool kids use brown switches.
source: I'm cool.
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
My friends who have used my Cherry MX Red Corsair K70 all get irritated that they can't type as accurately on it. I'm fine with it.
Corsair 5000D / Intel Core i7-12700KF / Arctic Liquid Freezer 3 360mm / MSI Meg Z690 Ace / RTX 3080 Ti Founder's Edition / 64GB Corsair Vengeance RGB 3200 MHz CL32 / Corsair RM1000X / 1TB ADATA SX8200 Pro (Boot) / 2TB Acer Predator GM7000 Gen 4 (Storage) / MSI MPG271QRX-QD / MSI Mag 274QRF-QD / LG CX 55" / G-Pro Wireless
