As title is called, I have been fiddling around the dimension of the custom case that I am creating and I just want to know before I continue with the project. What is better, the pros and cons of each one ? Can anyone answer please and thank you
I7 4790K • Corsair H110 • MSI Z97 SLI Krait Edition • Kingston Fury Hyper X (White)(16GB)(1866Mhz) • Crucial MX 100 512 GB • Seagate Barracuda 1TB • Phantek Enthoo Pro • EVGA G2 750 Watt
Asus DRW Optical Drive • TP Link Wifi Adapter • Asus MX279H • CM Devastator Bundle (Blue) • Bitfenix Spectre Pro (White) • Windows 8.1
Galax Hall Of Fame 970
https://linustechtips.com/topic/225835-atx-vs-mitx/
atx more ram slots and more expansion slots
mitx less expensve normally two ram slots less everything normally has wifi onboard
m-atx middle ground cna have two gou and one expansion card up to 4 ram slots i would reccomend this route  a little more expenxive than mitx but less than atx
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3093354
You get loads more expansion in an atx case.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3093355
Neither one is 'better' than the other. There are very good motherboards in both form factors. It just so happens that mITX is smaller than ATX, a lot smaller.
Since mITX is smaller it obviously can't fit as much 'stuff' on it. You typically top at out at 4 ram slots (some boards only have 2) and you will only have 1 expansion slot.
If you want a small computer, and only want 1 graphics card, mITX is a great option.
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3093744
ATX is bigger than MITX and you can get more expansion slot and RAM slot on an ATX board
The build route that I plan on going is:
Type|Item|Price
**CPU** | [intel Core i7-4790K 4.0GHz Quad-Core Processor](http://ca.pcpartpicker.com/part/intel-cpu-bx80646i74790k) | $358.95 @ DirectCanada
**CPU Cooler** | [Corsair H100i 77.0 CFM Liquid CPU Cooler](http://ca.pcpartpicker.com/part/corsair-cpu-cooler-h100i) | $103.99 @ Canada Computers
**Motherboard** | [Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard](http://ca.pcpartpicker.com/part/gigabyte-motherboard-gaz97xsli) | $134.99 @ Canada Computers
**Memory** | [Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory](http://ca.pcpartpicker.com/part/corsair-memory-cmy16gx3m2a1600c9r) | $187.98 @ Newegg Canada
**Storage** | [samsung 840 EVO 500GB 2.5" Solid State Drive](http://ca.pcpartpicker.com/part/samsung-internal-hard-drive-mz7te500bw) | $255.71 @ DirectCanada
**Storage** | [seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive](http://ca.pcpartpicker.com/part/seagate-internal-hard-drive-stbd2000101) | $113.50 @ Vuugo
**Video Card** | [Asus GeForce GTX 980 4GB Video Card](http://ca.pcpartpicker.com/part/asus-video-card-gtx9804gd5) (2-Way SLI) | $619.99 @ NCIX
**Power Supply** | [EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply](http://ca.pcpartpicker.com/part/evga-power-supply-220g20850xr) | $126.99 @ NCIX
**Operating System** | [Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)](http://ca.pcpartpicker.com/part/microsoft-os-885370635690) | $108.34 @ TigerDirect Canada
**Case Fan** | [Aerocool DS 140mm Blue 93.4 CFM 140mm  Fan](http://ca.pcpartpicker.com/part/aerocool-case-fan-ds140mmblue) | $28.84 @ TigerDirect Canada
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | $3030.47
 | Generated by PCPartPicker 2014-10-01 17:01 EDT-0400 |
While it is like that, due to my case originally being a tad small, I have to remake it so that it can fit the components that I plan on choosing, however I was just debating if I was to go a smaller form factor, like the MITX or MATX would it still fit all item's that I plan on going for
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3094110
You can't use two cards on an mITX board. There's only one slot.
You can use them on an mATX or any size larger than that.
Why three 2tb drives?
Whether or not you can fit all that depends entirely on your case. They come in a wide variety of sizes.
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3094169
Forgot to remove 1 of the 2TB drives, was planning on getting just 2 haha
OT: Yeah my case I decided to do it, about 16.5inches (H), 14.3 inches (W) & 15.6 inches (D) still doing a draft build to see and hope it all fits haha
https://linustechtips.com/topic/225835-atx-vs-mitx/#findComment-3094291
