Best GTX 970 to use with AIO cooler.
Heiltdo
Hello,
I'm looking to upgrade my 770 with a 970 in a few months but i have a NZXT G10 with its AOI water cooler, i was wondering what brand/model would be good for heavy OC but wouldn't carry a premium for a high performance cooler since it will go to waste.
I'll test it for a month before taking the cooler off so if anything funny happens i wouldn't have voided the guarantee.
An EVGA blower reference card. May not overclock to the limit, but is guaranteed compatible. That, the G1 Gaming card, or a TFV. It's a waste to take the cooler off of one of those though IMO, too good for a Kraken.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
Any reference cooler will be compatible. EVGA SC is not really necessary because you'll be overclocking it anyway with an AIO cooler attached. I would recommend the cheapest reference card from a trustworthy brand like Gigabyte or EVGA.
Superclocked cards are not binned, it will OC exactly the same as a normal reference 970.
I thought they were? Arent they?
No, the only cards that are binned are the matrix, classified, kingpin, lightning, and now apparently also there's a "SOC" thing from gigabyte.
Just keep in mind the VRM's on a GTX970 are at the opposite end of the card near the display connectors.
With means you need to rotate the bracket...
Well thanks for clearing that up.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
No problem :P
No problem :P
They should do a card that is binned like crazy and like 60% ASIC with a ref blower. Or no cooler at all. Fir the watercoolers.
Exactly what SchoolofMonkey said,  on some models of the 970s, (might be all, I don't know for sure) the VRMs are on the opposite side of the card, so be sure that whichever card you get is compatible.  Do research, and when in doubt, go EVGA because they back their products better than any other manufacturer.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
My eVGA GTX980 SC has an ASIC rating of 66% on reference blower..lol
Thanks for all the replies, i'll do more research on  that reference EVGA and ask them if they void the guarantee when you remove the cooler.
One last question, is the ACX 1.0 the exact same PCB as the ACX 2.0? the 1.0 version seems to be a lot cheaper.
