So I am building a pc and I am 99% sure that this would work but my father wants to make sure it will as I am 13 and he may be uncertain that I know what i am doing.
.Gigabyte AMD Radeon R9 280 WindForce 3X OC 3GB Video Card
.Intel Pentium G3258 Dual Core LGA 1150 3.2GHz Unlocked CPU Processor
.Corsair CX500M 500W Modular Bronze Power Supply
.Kingston HyperX FURY 8GB (2x 4GB) DDR3 1600MHz Memory Blue HX316C10FK2/8
.MSI Z97 PC MATE Intel LGA 1150 ATX Motherboard
.NZXT Phantom 410 Mid Tower Case Black
.Microsoft Windows 8.1 64bit DVD OEM
.Seagate ST1000DX001 1TB Desktop SSHD 3.5” Hybrid SATA3 Hard Drive
.Corsair Hydro Series H60 SE Liquid CPU Cooler
I am in Australia and this would cost about $1100.
Thanks!
https://linustechtips.com/topic/224809-pc-build-will-it-work/
Yep your all set. Even for the next 5th gen Intel processors. The Z97 will support the 5th gen (if you didn't know.) I'm not sure on the length of the 280 because I have a Nvidia graphics card and font focus on amd as a whole. If the card is too long you will have to remove a hard drive bay from the 410.
https://linustechtips.com/topic/224809-pc-build-will-it-work/#findComment-3079637
For that CPU I'd recommend an h100i or h110 just because your going to want to overclock it fairly high (I would think).
And for the same reason, an 80+gold power supply.
Dubs are better than subs
https://linustechtips.com/topic/224809-pc-build-will-it-work/#findComment-3079662
Everything in the build is compatible. I would suggest some changes that should improve performance.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($75.00 @ PLE Computers)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($75.00 @ CPL Online)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($130.00 @ Scorptec)
Memory: Avexir Core series 8GB (2 x 4GB) DDR3-1600 Memory  ($99.00 @ Mwave Australia)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($79.00 @ CPL Online)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($61.00 @ Centre Com)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  ($249.00 @ CPL Online)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case  ($124.99 @ Mwave Australia)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($88.00 @ CPL Online)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Total: $1095.99
Generated by PCPartPicker 2014-09-30 14:40 EST+1000
https://linustechtips.com/topic/224809-pc-build-will-it-work/#findComment-3080927
this might help
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($205.00 @ PCCaseGear)
Motherboard: Gigabyte GA-H97-GAMING 3 ATX LGA1150 Motherboard  ($134.00 @ CPL Online)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($95.00 @ Centre Com)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX Video Card  ($469.00 @ CPL Online)
Case: Cooler Master K380 ATX Mid Tower Case  ($53.00 @ CPL Online)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($114.21 @ Mwave Australia)
Total: $1131.21
Generated by PCPartPicker 2014-09-30 15:26 EST+1000
https://linustechtips.com/topic/224809-pc-build-will-it-work/#findComment-3081077
