Bottom two are 5mm jacks, and I believe the top two are XLR.
https://linustechtips.com/topic/224772-cable-help/#findComment-3079101
Top definitely look like XLR to me.
Yeah, they are, I just confirmed it via google images.
https://linustechtips.com/topic/224772-cable-help/#findComment-3079131
RTFM needs to be a requirement before posting a question.. :/
So true xD
https://linustechtips.com/topic/224772-cable-help/#findComment-3079204
Considering they're inputs, the bottom 2 are likely to be 1/4in sockets but can't really tell from the picture alone.
Edit: Did a quick google image search with your pic and googled the amp. They are in fact 1/4in sockets.
http://www.pyleaudio.com/sku/pta1000/1000-watts-professional-power-amplifiers
https://linustechtips.com/topic/224772-cable-help/#findComment-3080786
My friends just bought an amp for his computer's sub woofer and he needs to know what these inputs are called.
I hope the inputs are true balanced (I kind of doubt it). If so, there might be sense in going balanced IF you have a true balanced source.
I hope the fans are thermally-managed too, as they can get quite loud.
If you plan on bridging the amplifier (I suppose you are), check if it is stable down to the subwoofer's nominal impedance when in bridged mode.
https://linustechtips.com/topic/224772-cable-help/#findComment-3080831
