How's this for my next PC build:http://pcpartpicker.com/p/t7qjvK (copy and paste for it to work right) ...i'm sure you can read my current specs below.
And I already have a couple parts like the GPU,PSU,And 1 SSHD so it won't cost as much.
CPU¤Core i5 5675c ¤Cooler¤Ghetto water loop(Cheap tubing & block from amazon)¤GPU1¤Sapphire R9 290x Tri-x¤MOBO¤Asrock H97m Anniversary ¤RAM¤8GB DDR3 1866Mhz¤Storage¤2Tb SSHD & 320Gb HDD¤Case¤Cougar Spike Mini ITX case¤PowerSupply¤500w EVGA 80 plus¤
https://linustechtips.com/topic/224768-next-pc-build/
What?
Refresh page my link messed up
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079022
page not found and no specs below... wat
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079028
idk why it's not working i'm about to just delete post and repost
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079035
How's this for my next PC build:http://pcpartpicker.com/p/wMvTFT ...i'm sure you can read my current specs below.
What will you be using it for?
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079038
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079040
Try this http://pcpartpicker.com/p/t7qjvK copy and paste it
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079043
The link works, you just gotta delete everything after the ...
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079044
1440p gaming, video editing..ect
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079055
why not get a z97 instead of a z87?
Didn't notice that, but i'll take that into consideration
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079060
For video editing I'd say if you can fit a 770 then it'll be good for some 1440p and video editing. (cuda)
280 isn't really that good for 1440p
whats your budget?
edit you already got some parts.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079111
whats your budget?
didn't mean to have a 280 lol i have a 290x that i have now and i'll be using that
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079143
then don't get a g3258... try to fit atleast a i5 4440 if you must.
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079149
Wow so sorry wrong link..That's the real link that i have set up i'm soooo sorry for that copy and paste for it to work http://pcpartpicker.com/p/t7qjvK
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079164
haha it's fine.... that link doesn't work either. Try export and bbcode and copy and paste into here
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079180
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079207
lol it just won't work ima just delete post so i won't ruin the general discussions
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079210
@Matiox
Get an 80+ gold, minimum 500W. Especially if you want to overclock that cpu, which you definitely will. Also get z97 for better upgradeability
If it's that one then your golden (other than not having a Seasonic PSU)
Dubs are better than subs
https://linustechtips.com/topic/224768-next-pc-build/#findComment-3079216
